How to install Nitrous the correct way! I need input - Page 5
Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 104
Northstar Engines and System Technical Discussion Discussion, How to install Nitrous the correct way! I need input in Cadillac Engine Discussion; Originally Posted by eldorado1 The fuel line needs to be short. If you ran it all over the engine bay, ...
  1. #61
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    49
    2,759
    Re: How to install Nitrous the correct way! I need input
    Quote Originally Posted by eldorado1 View Post
    The fuel line needs to be short. If you ran it all over the engine bay, make it more direct shot. Solenoid to nozzle shouldn't be more than a foot max.
  2. #62
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    Initial Lean spike on a Closed throttle to WOT from a dead stop (17.1)
    The system goes a little lean on the 1-2 shift (13.6)
    This is the Lean Spike form the Nitrous jet opening (13.1)
    This is the Rich peak with the Nitrous on. (10.3) The bottle may have been getting weak
  3. #63
    NHRATA01 is offline Cadillac Owners Fanatic
    Automobile(s): '12 Regal GS, '01 Trans Am
    Jan 2008
    New York
    248
    Quote Originally Posted by AJxtcman View Post
    This is not a Returnless System
    A late model Northstar isn't returnless? I'll have to go take a gander when I finally change my oil this weekend. Thought GM implemented it across the board on their engines by around '01/'02 for emissions purposes?
  5. #64
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    The heater made the system go lean. I put a larger fuel jet in and turned up the fuel pressure 10%, but it still goes lean. I plan on dropping the fuel pressure 5% and making so more runs. The heater really helped getting consistent runs.
  6. #65
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    This or This?
  7. #66
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
  8. #67
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    [YOUTUBE]eC9w2alvIDI[/YOUTUBE]
  9. #68
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    Snap Shot: N2O vs NO N2O
    80mph in 10.079 and 1.576 faster than it was when we ran a 14.7 1/4 mile without N2O
    102mph in 15.243 on N2O vs 92mph in 15.379 on motor That would be a 10 mph increase and .136 second quicker.
  10. #69
    Highline Cady's Avatar
    Highline Cady is offline Cadillac Owners Fanatic
    Automobile(s): Nitrous03DHS,AJtune,Corsa,Volant,3.71s,Grille,tinted,stall'd
    May 2007
    Wisconsin
    40
    305
    I love it!!! I know it's not track slips, but the differences off the info off of the data logs and tech2, w/ n.o.s. and without are astounding, obviously it's a whole different animal on the go-go juice. We'll get her down to the track soon, just been so crazy lately, but will get it down to show off a amazing time slip soon to come.
  11. #70
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    Grr
  12. #71
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    The System has been going lean for a few weeks and we have not run it at the track for that reason.
    I Called Craig @ Nitrous Express and he told me that the rubber on the Fuel Solenoid Plunger could be swelling up. He asked me to check the color of the rubber and call him back. I removed the plunger and the seal looked fine to me. I called he back and told him it was tan in color. He asked me if the rubber was flush with the stainless steel. I replied No it is not. Hmm
    The fuel swelled up the seal and has been making my lean condition. Craig sent me out a special replacement Fuel Solenoid.
  13. #72
    Jan 2008
    New York
    248
    Well, I have heard reports of the ethanol in E10 wrecking the plunger gaskets on fuel noids. I think you may see quite a few more people toasting motors on spray now that E10 is pretty much country wide in its use. Supposedly NX was using a new gasket material, I think viton instead of rubber and has been for a couple of years. Was your kit new or used, I can't remember?
  14. #73
    May 2007
    Wisconsin
    40
    305
    Brand new. The fuel solenoid leaked when initially installed, so it's been suspect from the beginning. This crap gas finished it off? Apparently NX has a different better updated design for the crap gas, specify when you order, I guess. They're sending one.
  15. #74
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    Quote Originally Posted by NHRATA01 View Post
    Quote Originally Posted by Highline Cady View Post
    One more thing to add
    Craig mentioned Winter and Summer blends.
    Maybe we started with a Winter blend and the Summer blend killed it.
    We have 3 different types of Data Loggers, so we will know if the Summer blend needs more fuel by weight.
  16. #75
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    We are finally heading to the track.
    We have had a few problems that developed after having the system on the car for a few weeks.
    #1 the car was going lean after the Bottle heater was installed.
    #2 Rain rain and more rain.
    #3 My schedule
    The lean condition may have been caused by a plunger in the fuel solenoid. The original plunger had a tan rubber insert in the end of it. The fuel in our area caused the rubber portion to swell out past the end of the metal portion. I was informed that the plunger travels about .030 of an inch and the rubber was out about .015". The new plunger NX sent me had a black rubber material and it is actually recesses in the metal portion
  17. Remove Advertisements
