Please help 1995 STS "Service Engine Soon" jumping out of gear?
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Please help 1995 STS "Service Engine Soon" jumping out of gear? in Cadillac Engine Discussion; Hello, You have solved my past problems and I need your help again....... The "Service Engine Soon" idiot light comes ...
    Iansts is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac STS
    Dec 2007
    Islamorada Florida Keys
    8
    Hello,
    The "Service Engine Soon" idiot light comes on with no codes.
    While driving down the road at about 40-45 MPH the car shutters as though it has hit a speed bump and like it has slipped out of gear or has down shifted . The Tach goes erratic revs up down etc and the engine looses power as though it wants to shut down.
    This happens every once in a while about 3 miles or 10 minutes going down the road. Once you slow down to idle speed and then start to it drive again everything seems fine until it does it again.
    I tried to disconnect the Battery to reboot the computer when the first it happened to clear the memory, took it for a test drive with the same result.
    I checked the trans fluid as per specifications level was fine.
    Thank you for your help, Ian
    Dec 2007
    8
    Re: Please help 1995 STS "Service Engine Soon" jumping out of gear?
    P.S.
    I found a currant code of A010
    History codes are p056 p094 p109 I052 s044, No sir, no tcs
