2000 N* Rough Idle in Seville STS
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, 2000 N* Rough Idle in Seville STS in Cadillac Engine Discussion; At 50,000 miles, my 2000 STS began to develop a very mild case of rough idle. Every few seconds the ...
    SmoothTS is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    72
    Question2000 N* Rough Idle in Seville STS
    At 50,000 miles, my 2000 STS began to develop a very mild case of rough idle. Every few seconds the engine would shudder or vibrate a tiny amount, this could be seen when looking at the engine and can be felt when sitting inside the car at idle. Now, at 115,000 miles, the idle is somewhat worse, with the engine doing a slightly rougher shudder every second or so at idle. I changed the spark plugs about 1,000 miles ago, the old plugs didn't look too bad and the new plugs didn't help (and didn't worsen) the condition.
    I know there was a recall that involved new camshafts and other modifications. Is this the same condition I'm experencing? It's annoying but not a dealbreaker. Could it be something else?
    68
    81,917
    Re: 2000 N* Rough Idle in Seville STS
    2000+ Northstars have a rubber coupler AKA plenum between the TB and the manifold. They are known to split and cause a vacuum leak which seems to cause symptoms like yours. Spray some Brakleen around there and see if you get an RPM increase. If so, replace the "plenum".
    Jan 2008
    72
    A cracked plenum is indeed the problem! Thank you!!!
    1998STS's Avatar
    1998STS is offline Cadillac Owners Member
    Automobile(s): 1998 Cadillac STS
    Jun 2005
    Muskego,Wisconsin
    41
    20
    Thumbs downRe: 2000 N* Rough Idle in Seville STS
    I am having the same problem, only thing is I have a 1998 STS. Do 98 Caddies even have a plenum. If they do not have plenums,what else vacuum wise could be the problem. Does anyone have a picture of what a plenum looks like.Below is a list of what I have done so far. Thanks in advance.
    Plugs/Wires
    Cleaned Intake
    Cleaned EGR
    68
    81,917
    No, the "plenum" is on the 2000+ Northstars. Check all the vacuum lines including the PCV fitting. Don't overlook the intake mounts and do not over torque them.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    While you're in the front of the intake manifold listening for a leaking PCV fitting, stick the stethoscope further back in there and listen for a vacuum leak around the overpressure blowoff valve in the center end of the manifold.
    Intake manifold bolt torque is only 9 ft/lb. A 2000+ "plenum" is a very short bellows arrangement with a flange plate/bolt clamp on the TB end and a hose clamp on the other (manifold) end. Plenty of pictures in here a few months ago.
  9. Remove Advertisements
