heating and a/c system please help
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, heating and a/c system please help in Cadillac Engine Discussion; ok i live in md and right now its about 45 degrees outside but my outside temperature reads 85 degrees ...
    yungwun724 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    12
    ok i live in md and right now its about 45 degrees outside but my outside temperature reads 85 degrees on my car...and i notice when i set my heat on 90 degrees it gets real hot then when i turn it down 2 85 cold air blows from the vents at first cold air didnt start coming out until 75 degrees..can someone tell me wat the problem is?
    Sep 2003
    Metro ATL
    4,854
    Re: heating and a/c system please help
    What year-model of car?
    You should replace the outside ambient air temperature sensor because some year-model Cadillacs use that information as an input to the HVAC system.
    68
    81,883
    Yup, your car thinks it is 85 degrees, so when you ask for 75, it thinks it has to cool to reach that temperature.
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    69
    962
    So how does this happen? With defective out side air temp sensor it defaults to the inside air? Which years, very strange behavior, never heard of it... K_C
    Feb 2008
    12
    it iz a 97 deville
    68
    81,883
    I believe that the OAT sensor is also linked to the HVAC system. If it is 20 degrees outside and the car thinks it is 95, it is going to cool to reach a requested 75 rather than heat to do it.
    Feb 2008
    12
    where is my outside temperature thermonitor located at
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,834
    It's the small black item at the end of a covered wire clipped to the front of the hood latch/radiator support. Single plug with safety catch. New unit is about $14 at www.rockauto.com. BTW, it's a thermistor; a resistor which changes value as temperature varies.
  11. Remove Advertisements
