p0340 camshaft position sensor
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By loudes13
Northstar Engines and System Technical Discussion Discussion, p0340 camshaft position sensor in Cadillac Engine Discussion; 2000 deville replaced crankshaft position sensors 2 years ago been getting p0340 for last year starts and runs fine looking ...
    pugel's Avatar
    pugel is offline Cadillac Owners Member
    Automobile(s): 05 DTS 145k, 00 Deville 201k, 97 Deville 175k, 95 Vette 115k
    Jul 2004
    29
    2000 deville
    looking for steps to replace camshaft position sensor
    must be on this site somewhere but I can't find them
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,856
    Re: p0340 camshaft position sensor
    Unplug it (only one), take it out, install new sensor. No relearn procedures or PCM resets necessary.
    Located on "front" (drive end) of rear cam cover, below and behind power steering pump. 1 bolt and short electrical connector.
    It's in a location that is subject to road spray whipped by the serpentine belt, and maybe also subject to oil from a tiny weep in the front of the cam cover. You might get away with just an electrical connector cleaning.
    loudes13 is offline Cadillac Owners Member
    submariner, where exactly is the cam pos sensor? I removed the plastic engine cover and can't find it. The PS pump is closer to front bank than the rear.
    This is on a '97 Eldo.
    Allen
    loudes13 at yahoo
    68
    81,894
    If memory serves me correctly it is on the back of the right head, close to the EGR valve and master cylinder.
    Feb 2006
    55,856
    Just below the front of the right (rear) cylinder head cam cover. Electrical connector and 10mm bolt into a retainer tab.
    thanx, it was unplugged. Glad I didn't need to get a wrench in there, it was a tight fit for my hand.
    If anyone needs a CPS, let me know. You can have it for the cost of postage.
    scamp340 likes this.
  9. Remove Advertisements
