No spark,Please help !!
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Northstar Engines and System Technical Discussion Discussion, No spark,Please help !! in Cadillac Engine Discussion; I just finished changing engines in my car.The car cranks over but i have no spark.We looked over all the ...
    dennii825's Avatar
    dennii825 is offline Cadillac Owners Member
    Automobile(s): 1997 Eldorado~1999 Escalade
    May 2006
    Reading Pa.
    45
    78
    I just finished changing engines in my car.The car cranks over but i have no spark.We looked over all the wire harness made sure everything was hooked up,before we set the body back down.it all looks to be conected.This is driving me crazy (HELP). I know there are many of you on here with alot of knowledge with northstars,i sure could some of it now.What are some of the things i can start checking?
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: No spark,Please help !!
    No codes?
    Well, you'll just have to trace it back. No spark at the spark plugs check for spark at the wire, no spark there check for spark at the coil packs (be careful they will shock you without hesitation if you give them the chance), no spark there then remove a coil pack and check for spark at the ICM, No spark there check the power source for the ICM (would give a code) as well as the camshaft position sensor.
    roger greeb is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2008
    43
    dennis...roger here.,,,,i kinda like that last guys answer...still got the gas and the match here...i thought about what krsashed said after yr mail...no codes? mayb no spark equals no codes..but damn it man...surely u already been there...be careful wih those packs...ouch! ttyl good luck
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    def pull your codes
    next borrow a scanner and check the paramaters with the engine on such as the TPS sensor....
    dennii825's Avatar
    May 2006
    Reading Pa.
    45
    78
    I took the coil pack and ICM off my original engine and put in on the new engine and still no spark.
    I was thinking,I dont know if this would do it but with there being 2 crank sensors and i believe the same style plug that i could have them switched a to b, b to a could that give me no spark?
    Oct 2005
    15,987
    i dont THINK so
    but its an easy fix to try switching them...
    Ranger is online now Cadillac Owners Member
    68
    81,883
    I thought the CKP sensors where made so that they could not be switched.
    Oct 2005
    15,987
    i would assume that too
    but there isnt a special list on a crank A sensor and a crank B sensor on GM parts....
    just a list for a crank sensor...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    A and B are two different part numbers.
    A is the lower, B is the upper. Different electrical connectors. Flats on sensor barrel are on different sides.
    dennii825's Avatar
    May 2006
    Reading Pa.
    45
    78
    hey jay
    I looked in my FSM and found conector end view, in engine controls components locator.
    conector end view 8a-202-76 sensor A
    conector end view 8a-202-76 sensor B
    I also found this in an old post,
    Ok, we put the new coil pack on it and found that we needed to reverse the wiring on the crankshaft sensor. After doing that, it fired right up but ran rough with a P074 and P053 codes. No other codes came up, we shut it down after a few seconds of running, and that's where we're at right now.
    I really hope thats it,now i have to get to shop and check it,but the 3 lifts are tied up right now.
    thanks
    Hey sub just red your post guess that rules this one out.
    Thanks
    dennii825's Avatar
    May 2006
    Reading Pa.
    45
    78
    Just a follow up on this thread, Last night I was reading in my FSM about CKP's (same plugs).crank sensor A top yel-ppl wires, crank sensor B bottom blk/wht-ltblu/wht wires.I got a chance to get it back up on the lift tonight and checked them they were switched.I switched them around and it fired right up.
    I just want to THANK all you guys for all your help.
    This engine swap was not as bad as i expected.If you have the right tools and some patience you feel real good after it's done.
    Thanks again,
    Dennis
    matin1999 is offline Cadillac Owners Member
    Automobile(s): 1999 cadillac seville sls
    Mar 2010
    29
    21
    My name is mark im having the same problem what kind of engine are yall talking about?
    68
    81,883
    Northstar
  16. #14
    Mar 2010
    29
    21
    Northstar
    What year and model of cadillac?
  17. #15
    Feb 2006
    55,840
    Pre-2000 Northstars use the same CKP sensors in position A and B. 2000 and on use different sensors - in the new replacement DENSO series one is black, the other gray.
  18. Remove Advertisements
