Which Head Gasket to use?
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Which Head Gasket to use? in Cadillac Engine Discussion; Looking for input or suggestions on what brand of head gasket to use. Stock from GM, Cometic or something else? ...
    97 STS is offline Cadillac Owners Member
    Automobile(s): 97 STS
    Jan 2008
    Auburn, Wa
    25
    97 N*.
    sipur is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Mar 2007
    9
    Re: Which Head Gasket to use?
    go to http://www.autopartswarehouse.com/ and chek The $$
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,936
    Never used a Cometic gasket in a N*, but we use copper/stainless sandwich head gaskets in marine Olds 455 conversions and have never had a failure. Pricey but good insurance. One of our GM techs may have some experience with Cometic/N*.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by 97 STS View Post
    97 N*.
    I am aware of several people that have Cometic head gasket in Northstars. I have never had one in my hand yet. I have one of my customers that is in a current build. He said that he is going to apply some hylomar to parts of the gasket. The stock 3.6L head gasket are MLS and they have a coating on the gasket around the coolant passages. I think it is Teflon, but I was told that is the coating FelPro uses on the gaskets. I was told that about 20 years ago.
    I honestly can't see if the block had Norm's inserts and this head gasket combination that it would ever fail again. I would seal the Case Halves up with the new procedure. It would cost less the $100 more. Then you would never leak oil or have a head gasket failure. You could pull the engine in 10 years and put it in another car.
    The Big Timesert may work just as well as Norm's, but I have never had one in my hand. GM does not approve of either one.
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    I forgot one thing
    The 4.4L S/C Northstar uses a MLS type gasket.
  8. Remove Advertisements
