are coils interchangible from front to rear?
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, are coils interchangible from front to rear? in Cadillac Engine Discussion; i suspect i have a coil problem with my 01 dts. i have a spare but its for the rear. ...
    pontiacsouth is offline Cadillac Owners Member
    Automobile(s): NONE
    Jul 2007
    CALIFORNIA
    67
    i suspect i have a coil problem with my 01 dts. i have a spare but its for the rear. i was going to try to replace the front coil since its a lot easier. will the rear work on the front or are they different??
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    Re: are coils interchangible from front to rear?
    If you look in www.rockauto.com you'll see two different part numbers for coil cassettes (4 coils in each), one # for front, one # for rear.
    Automobile(s): NONE
    Jul 2007
    CALIFORNIA
    67
    i know they are 2 different part numbers & one is black & one is gray. my question is would the rear work on the front??
    Feb 2006
    55,891
    Either pull the whole thing apart and compare the parts themselves or wait for AJ or eWill3 to come aboard. My 2 are also different colors, but look similar. Never occurred to me to compare the connectors last year......gotta be something other than just color......
    Automobile(s): NONE
    Jul 2007
    CALIFORNIA
    67
    my hunch says they are different. i bought a used one off ebay, they said it was the front bank in the auction, but they sent me the rear & said it is interchangible. i just wanted to know for sure before i waste my time taking it appart. i appreciate your help, I'll just have a beer in the meantime....
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,117
    They are identical.
    The front is painted silver. The rear is black. GM suggestion program?
    They are interchangeable. No problem.
    I carry a spare coil bank in my trunk.
    That being said..I have seen 2 versions of the IC plug in.
    Logan Diagnostic LLC
    www.ledfix.com
    www.airbagcrash.com
    www.logandieselusa.com
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Yep, they are swappable.
    They are just different colors. The plugs are the same, the bolt holes are the same, and the coil tower locations are identical.
    I swap them sometimes to diagnose a misfire, I also keep some old ones laying around with the bad coils marked.
    If I get a car with a miss I'll swap it out with a known bad one and see if the misfire moves... if it does I replace the coil.
    GM has no other real way for us to test them.
    Automobile(s): NONE
    Jul 2007
    CALIFORNIA
    67
    well, i swapped coils when i got home last night, before i saw the answers above & the misfire is gone. Glad that worked. nice to know that they are swapable if that ever happens again.
    thanks guys!!
  11. Remove Advertisements
