Northstar Over Heating After Waterpump Replacement
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Northstar Over Heating After Waterpump Replacement in Cadillac Engine Discussion; My 1998 cadillac Eldorado is over heating after I had replaced a leaking water pump. It never had this problem ...
    doughboy is offline Cadillac Owners Member
    Sep 2005
    QuestionNorthstar Over Heating After Waterpump Replacement
    My 1998 cadillac Eldorado is over heating after I had replaced a leaking water pump. It never had this problem with over heating before. Also there is no heat until I raise and drop my rpm to about 3000rmp 4 or 5 times. After that there is heat and the temp will drop down. I replaced the thermostat still has the same problem. Upper hose doesnt feel like it has coolant in it. I took the hose off and fill the pump and hose. Ran it for a bit still empty. Air purge line is clear. Anything would help thanks guys.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Re: Northstar Over Heating After Waterpump Replacement
    Got to be air in the system. I haven't had any trouble with this car, but in the past, I have parked my car "up-hill" to help get rid of the air after re-filling it with coolant.
    68
    81,926
    Yup, gotta be air in it. Since the purge line is clear, run the RPM up to 3-4K a few times to purge the air. Make sure that the surge tank is 1/2 full.
