Root Cause of Head gasket Failure and a Fix? - Page 2
Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 16 to 30 of 179
Like Tree10Likes
Northstar Engines and System Technical Discussion Discussion, Root Cause of Head gasket Failure and a Fix? in Cadillac Engine Discussion; This is two of the head bolts. As you can see they have NO aluminum on them. I did not ...
  1. #16
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    49
    2,759
    Re: Root Cause of Head gasket Failure and a Fix?
    This is two of the head bolts. As you can see they have NO aluminum on them. I did not see any of them with aluminum on them.
  2. #17
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    This is one of head gaskets. It really fell apart. This had a lot of stop leak in it
    This is some of that bunching I talk about
    This part did not look that bad, but It has a lot of stop leak.
    This is some rust on the head gasket
    This stop leak really attacked the gasket
    More of that stop leak build up.
    The stop leak was so thick it plug the holes in the head gaskets and in the heads. Stu (the tech) had to use a drill to clean out the steam holes.
  3. #18
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    GM will not warranty the Big Timesert or Norm's. GM states that if the bolt hole has erosion you can not TimeSert it and you must Replace the short block.
    From my understanding all 1998 cars are now out of Warranty. With in a year all 1999 will be out they will not have any more 1999 and older Certified cars left under warranty.
    JUMPPED POST AGAIN
    I would never purchase a 96 to 99 Cadillac unless it was a 98 or 99 Seville and that maybe limited to a STS.
    You can buy a 2002 or 2003 Seville for $6500 with 100K+ miles. A 99 Deville maybe worth $3k to $6K. Subtract the $3000 to $6000 for head gaskets and you have JUNK.
    A 99 STS with 100K will go for $9000 now you can fix the car.
    The reason I say up to $6000 in head gasket repairs is because of the cam shaft failure in the 93 to 99 models.
    the pictures are 4 years old. We had a higher level of zinc then.
  5. #19
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    Make: GM
    Engine: Cadillac V8 4.6L
    Description: Northstar 4.6L 32V Left Side
    Bore: 3.700"
    Material: MLS / C.O.T. - .065"
    StockCode: C5716-065
    Pkg Qty: 1
    Price: $118.09
    Make: GM
    Description: Northstar 4.6L 32V Right Side
    Bore: 3.700"
    StockCode: C5717-065
    Pkg Qty: 1
    Price: $118.09
  6. #20
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
  7. #21
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    I had forgot about this company until I got a phone call last night.
  8. #22
    97 STS is offline Cadillac Owners Member
    Automobile(s): 97 STS
    Jan 2008
    Auburn, Wa
    25
    AJ, are these aftermarket gaskets?
  9. #23
    JC316 is offline Cadillac Owners Connoisseur
    Mar 2005
    DFW Texas
    31
    1,406
    Very interesting writeup AJ, well done. My 98 SLS blew the gasket, but for a different reason than the one that you showed. The metal on my block was great, no pits or corrosion, hell the threads didn't even pull out, what killed mine were two gashes in the surface of the head, near the water jacket. I assume that they were a factory flaw from the factory, but I never did find the reason. In your estimation, since the block was in good shape, no powdered shavings, or pits, what are the chances of my 98 blowing a head gasket again?
  10. #24
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    Quote Originally Posted by 97 STS View Post
    YES
    They maybe the OE supplier of that type of gasket for some engines. I am not sure about that, but some is making then for GM.
    Quote Originally Posted by JC316 View Post
    No pitting, No powder, No TimeSerts then the block should hold up just fine
  11. #25
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,180
    AJ, It's too bad that CF doesn't pay an hourly rate. Thanks for the extensive homework. The complete set should be a Northstar or Tech sticky.
  12. #26
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Thanks for the info, I will watch more carefully when I do another one. Maybe I'm lucky so far!
    I did realize there was a difference on some holes when I drilled them but didn't record or check them as well as you have.
  13. #27
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    My bad holes were very obviously different from my good holes. The good ones snapped really hard when they broke loose and the holes and bolts were dry. The bad ones were wet with coolant (I think). They was a slimy - and silvery coating - it was almost like anti-seize compound on the bolt threads. I think only one of them was completely stripped, but I drilled and inserted them all. I don't recall seeing any powdery aluminum - maybe I missed it.
    I have given this a lot of thought, and I think (just a theory - just an opinion) the head gaskets let go first, allowed coolant & exhaust gases into the bolt holes and that degraded and corroded the aluminum to the point where the bolts let go, and the exhaust then entered the cooling system in a big way.
  14. #28
    Mar 2005
    DFW Texas
    31
    1,406
    Quote Originally Posted by AJxtcman View Post
    YES
    I used the Timeserts on mine, they seemed to lock in nicely and I haven't seen a problem yet after 10,000 miles.
  15. #29
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    49
    2,759
    I have TimeSerted many thing over the years. On a Northstar Block the Drill/Ream is centered with a jig and then the drill goes down into the bore about 3" before it drills out the threads. This would mean that it is pretty well centered! Yeah right. The block was square at one time also. Do you understand that? OK the block goes through heat cycles and the bolt holes become slightly curved. When the drill gets to the bottom it drills ever so slightly off center. Maybe it goes towards the soft stuff. That would a good thing. Just think about this you have a drill in a 1" collar square to the deck and then it goes into a bore another 3". That means that it is held centered and square by a 4" tube. So why is it that I see so many off center? They hold up, but I just saying. So if one of the 20 hole is not perfect then the block is junk after the TimeSerts have been installed and they fail. If you just fix the bad ones and 75K later a different one fails you can fix the ones needed.
  16. #30
    dwight.j.carter's Avatar
    dwight.j.carter is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Seville STS
    Aug 2004
    Des Moines, Iowa, United State
    37
    2,067
    excellent write up this is a very good read if you are a northstar owner.
  17. Remove Advertisements
