Root Cause of Head gasket Failure and a Fix? - Page 11
Page 11 of 12 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 151 to 165 of 179
Like Tree6Likes
Northstar Engines and System Technical Discussion Discussion, Root Cause of Head gasket Failure and a Fix? in Cadillac Engine Discussion; Originally Posted by Inkredible MaduraMi, did you pull your engine out the top or bottom? Mark He hasn't been here ...
  1. #151
    Submariner409's Avatar
    Submariner409 is offline If it won't run, stick on fender vents
    Feb 2006
    MD Eastern Shore, Kent Island
    55,590
    Re: Root Cause of Head gasket Failure and a Fix?
    Quote Originally Posted by Inkredible View Post
    He hasn't been here in a long time.............
    It sounds daunting, but for the home DIY, dropping the whole drivetrain makes the most sense. You can stud the block without removing the engine from the cradle. If the lower end is tight there's no sense taking the engine completely apart.
    You will need a real GM/Helm service manual - lots of settings and torque work to pay attention to.
  2. #152
    Inkredible is offline Cadillac Owners Fanatic
    Automobile(s): 91 Deville
    Jun 2011
    New Hampshire
    59
    151
    Hi Sub,
    I was curious how he did it. I know that it can be done in the car with studs, but I have heard that the engine has to be tipped forward, and wanted to find out if that was true. I have a chance to buy a nice 2000STS for cheap that has a blown HG. And anyways, can they all be done with the engine coming out the top is what I want to know. Does the FSM say to take the engine out from the bottom?
    Mark
  3. #153
    Carroll Cadillac is offline Banned
    Automobile(s): '00 SLS, '65 CoupeDev, '96Dev, '89Eldo, '01DTS, etc...
    Jul 2010
    Ridgefield, WA
    31
    • The finest Northstar Head Stud to date, correctly engineered to be installed at the correct depth.
    • No multiple types of studs to deal with.
    • No confusion or complications.
    • No expensive Jig plate to buy.
    • Installation takes less time.
    • Full tech support, we will always answer the phones or return your call within minutes.
    • Studs shipped immediately!!! (2-3 day priority)
    • Unlimited stock on hand.
    • There is an alternative to both Timeserts and the studs in question.
    • In collaboration with the leading head stud manufacture, ARP, and based on GM's technology of proper depth.
    • There is NO other stud more reliable or easier to install.
    • Less expensive and over engineered to out perform all other manufacturers.
    These studs are being sold world wide, with a lifetime warranty and they are completely utilitarian.
    We have provided the complete specs on these studs for your convenience.
    Why? Because Cadillac's is our hobby, and making it affordable to own one is our goal.
    We are Cadillac Clubs Northwest and do what we do for the love of the car.
    Call or email us anytime for a consultation or feel free to stop by our Cadillac Ranch.
    Come and visit our Cadillac restoration department where Cadillac's is all we do!
    Carroll Custom Cadillac
    http://carrollcustomcadillac.com
    503-895-2124
    6610 NW 299th ST
    Ridgefield WA 98642
    mtflight and mtflight like this.
  5. #154
    Tankboy40's Avatar
    Tankboy40 is offline Cadillac Owners Fanatic
    Automobile(s): '93 ETC (N* 120k)
    Jun 2012
    Akron Ohio
    44
    328
    but ultimately, there is a cause of the failure... overheating mainly (right)
    These parts dont just fail without some sort of precipitating factor.... yes?
  6. #155
    phoenix.rj is offline Cadillac Owners Member
    Automobile(s): 97 sts
    Dec 2010
    67
    1
    I have a 97 STS. Two years ago ,it At 120,000k, it started using coolant through the exhaust at a rate of a gallon per 30 k. since the cost was prohibitive for a 13 year year old car, $6k-$10k, I took a chance on a formula out of California for $300. Although, I'm not a certified mechanic, I have work on about every aspect of cars, including repairing many heads throughout my 63 year, so I never believed in a cure out of a bottle. In this case, I love the car and to repair the "right way" was out of the question, so I tried a product called Thermo Gasket, and to my surprise - IT WORKED. Today I have over 150,000k on it, live in a cold climate, Canada, and my car is runs like a clock. I keep my eye on the coolant and have to add about a liter every 6 to 9 months. I can live with that.
  7. #156
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Tankboy, overheating is a symptom not a cause ... the cause is the whole reason for this thread
  8. #157
    Feb 2006
    55,590
    Quote Originally Posted by Tankboy40 View Post
    but ultimately, there is a cause of the failure... overheating mainly (right) These parts dont just fail without some sort of precipitating factor.... yes?
    You have the cart before the horse: Overheating for some reason will NOT cause the head bolt hole threads in the block to fail; rather, the threads disintegrate for one of several reasons, one or more bolts lose clamping pressure, the gasket begins to fail, exhaust gas enters the cooling system and blows off coolant, leading to water pump cavitation and subsequent overheating.
    The exhaust gas, in and of itself, does not overheat the engine. I believe the open deck design is contributory to gasket failure. Even though the head gaskets incorporate a stainless steel fire ring, perhaps the block (each cylinder) should also have been O-ringed - read up on the procedure.
  9. #158
    Black Beauty DTS's Avatar
    Black Beauty DTS is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac DeVille DTS
    Apr 2012
    285
    I'm wondering if anyone knows if any lab tests were done to determine how corrosive the Dexcool becomes if left in the cooling system for 5 years or more. I know that it becomes more acidic, but test results would help to prove if this is one of the leading causes of thread failure.
  10. #159
    68
    81,764
    Not that I have ever heard of, but that does not mean much.
  11. #160
    Feb 2006
    55,590
    nyukcubed, Your post and coolant question has been moved to a new thread in the advice section, down about 8 threads below this one. "2000 STS coolant problems".
    You'll get far more exposure and advice if you keep your questions out of the "sticky" posts.
  12. #161
    1stkobefan is offline Cadillac Owners Member
    Automobile(s): Cadillac DTS
    Apr 2008
    FL
    33
    27
    Thanks for the info.
    I need to know what's a decent/avg price for head gasket replacement on an 02 DTS?
    Is this something I should have done by a GM/Cadillac service center ONLY?
    If I understood correctly the inserts aren't necessary if the block itself isn't damaged and the 2003 or later bolts are used? But if there block damage the inserts have to be used?
  13. #162
    Feb 2006
    55,590
    Inserts or studs are used regardless - the head gaskets fail due to cylinder block bolt hole thread failure, not the other way around.
    A head gasket job at a Cadillac dealer will easily run $4,500 ++++.
    Try to get in touch with either Jake at www.northstarperformance.com or Tim at www.carrollcustomcadillac.com or Norm at www.huhnsolutions.com and find out if there is/are shops in your area doing the work and using their head stud/insert (bulletproof) kits. Usually half the dealer pricing.
    Go back and read Post #159 - plus as much of this thread as you can ........... it's all in here.
  14. #163
    jamie1 is offline Cadillac Owners Member
    Automobile(s): 1998 STS
    Apr 2012
    63
    71
    In looking at the 'solutions', huhnsolutions uses inserts, northstarperformance and carroll use studs with large threads for the block. Other than huhn giving you the option of studs or bolts, any reason to choose one or the other?
  15. #164
    68
    81,764
    Not really. Either way will get the job done. Studs are far better if you are going to pull the heads again, but nobody ever plans on doing THAT twice.
    P.S.
    Timesert also offers the coarser thread pitch. That would be their Bigsert.
  16. #165
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    677
    Could someone please direct me to the thread about rwd or awd Northstar head bolt issues compared to fwd Northstar head bolt issues. Thanks. Or please give you're opinion on the matter.
  17. Remove Advertisements
