Root Cause of Head gasket Failure and a Fix? - Page 10
Page 10 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 136 to 150 of 179
Like Tree7Likes
Northstar Engines and System Technical Discussion Discussion, Root Cause of Head gasket Failure and a Fix? in Cadillac Engine Discussion; Originally Posted by Pete1996 Has anyone noted if it is the front or rear bank that fails more often? No ...
  1. #136
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    Re: Root Cause of Head gasket Failure and a Fix?
    Quote Originally Posted by Pete1996 View Post
    No rhyme nor reason - some bolt holes fail, some don't. Some theorize that two cylinders, adjacent to each other in the firing order, might be questionable but that doesn't seem to hold water either.
  2. #137
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by submariner409 View Post
    "doesn't seem to hold water" - very funny Sub!
    AMG likes this.
  3. #138
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by AJxtcman View Post
    Norm always has them on Ebay
    Search: NORTHSTAR ENGINE NS300L HEAD BOLT THREAD REPAIR KIT
    The Head Gaskets come from. I would call them to make sure they fit the application. I know they fit 93 to 99. They may have other years also
    Norm has improved his kit http://www.huhnsolutions.com/
  5. #139
    MaduraMi is offline Cadillac Owners Member
    Automobile(s): '99 Deville
    Aug 2010
    48
    4
    Just installed the Stud Kit from Northstar Performance in my '99 Deville. I looked at all of the different options and just figured that since the pricing wasn't all that different between the various kits when you add in the cost of a new set of head bolts I'd go with the studs. Racing engines all get studded and I figured those guys must know what they're doing. When I had questions I was able to call and speak to Jake who didn't seem to be in a hurry and took plenty of time with me. I have driven a thousand miles since the repair with some WOT and long distances on the freeway and my temps have been rock steady. The motor purrs now. I'm very satisfied and confident that I won't have to revisit this issue again with this car. Now that I've done one I wont be afraid to do it again. If anyone has any questions about the process feel free to ask.
    Paul
    76eldodude and 76eldodude like this.
  6. #140
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,126
    AJ,
    Nice posts. I can appreciate all the effort you put into the detail descriptions. I haven't gone through this section yet, but I will. You left some very good information.
    Thanks
  7. #141
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Here are Jake's studs that I received for my eldo.
    I took pictures of two studs, the plate and it's mounting hardware.
    If you notice the mounting hardware has two sets of different size bolts. It's obvious the smaller of the two are the original size bolts.
    Look at the larger bolts and the thread pitch. Look at the studs. The larger end of the stud is what is getting bolted into the block, now compare that to the fine thread on the mounting bolt(smaller threaded mounting bolt).
    It's night and day.
  8. #142
    studebaker is offline Cadillac Owners Member
    Automobile(s): looking for an ETC
    Jan 2011
    26
    The stud concept seems to make more sense than using bolts.
    Far greater strength, plus the torqueing action of clamping down force takes place without twisting on aluminum threads.
    Studebaker
  9. #143
    98eldo32v's Avatar
    Apr 2010
    51
    2,126
    Precisely.
    Why take the chance of ruining the threads when you can tighten down the nut/washer combination?
    In the end I guess it boils down to your preference. In my case, it's studs.
    I'm now deciding whether to use that cometic multi layered steel gasket after reading AJxtcnman's post.
    I was comtemplating it already but now he's almost shoved me in the corner with his pictures of the factory headgasket "crunching up" in certain spots.
    I plan to keep this car a while and I'm NOT going back in to do this repair again anytime soon.
    I like to fix it and forget it.
  10. #144
    luminazkidd21's Avatar
    luminazkidd21 is offline Cadillac Owners Member
    Automobile(s): 2001 DTS 96'ELDO ETC (had)
    Mar 2007
    Houston Texas
    36
    23
    So my 01DTS has blown its gaskets, 99K never over heated, I want to do the studs and the composite gasket but because of my work and where i live theres no way id be able to do it on my own..Can ANYONE reccomend a shop between Austin or San Antoino that can do this work??? I LOVE MY DTS and makes me ill at the thought of getting rid of it
  11. #145
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    I'm not the best with Texas geography but there's a shop in Dallas who will do the work for you. North Texas Performance. Also Crest Cadillac in Plano, TX.
  12. #146
    Feb 2006
    55,857
    Quote Originally Posted by 97EldoCoupe View Post
    Jake, he posted this somewhere else, too. I think there were a couple of replies concerning Texas shops.
  13. #147
    Mar 2007
    Houston Texas
    36
    23
    Yeah I found a listing for the shop in Dallas. I appericate all the help guys! I really do!
  14. #148
    caddypit is offline Cadillac Owners Member
    Automobile(s): sts
    Jan 2009
    1
    Very informative,
    I have a 95 sts, timeserts where done about 90,000 mile ago and it’s now leaking again, with your history in this problem would it be possible to do additional repairs at this point? I used to be a machinist so do as much as possible myself if possible and if having the specialty tools
    Thanks
  15. #149
    Feb 2006
    55,857
    Quote Originally Posted by caddypit View Post
    Very informative, I have a 95 sts, timeserts where done about 90,000 mile ago and it’s now leaking again, with your history in this problem would it be possible to do additional repairs at this point? I used to be a machinist so do as much as possible myself if possible and if having the specialty tools Thanks
    Talk directly to Jake at www.northstarperformance.com or Norm Huhn at www.huhnsolutions.com
    These are the guys who make the studs and inserts from scratch - they have the real answers.
  16. #150
    Inkredible is offline Cadillac Owners Fanatic
    Automobile(s): 91 Deville
    Jun 2011
    New Hampshire
    59
    151
    MaduraMi,
    did you pull your engine out the top or bottom?
    Mark
  17. Remove Advertisements
