Oil burning TSB.. I know this has been talked about before
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Oil burning TSB.. I know this has been talked about before in Cadillac Engine Discussion; I know there was a TSB Released about the excessive oil burning. My 99 STS does not leak oil anywhere ...
    foos is offline Cadillac Owners Member
    Automobile(s): 99STS
    Mar 2008
    Florida
    49
    I know there was a TSB Released about the excessive oil burning. My 99 STS does not leak oil anywhere but still uses 1 quart every 500-1000 miles depending on how I drive it, and mor towards the 500 mile range because I drive it hard all the time. It looks like a lot of oil is coming through the PCV system as a vapor but I can't be sure. There was a TSB that the dealer could put some liquid into the cylinders that would clean up the rings but I can't find it anywhere; does anyone recall this?
    Thanks!
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Oil burning TSB.. I know this has been talked about before
