Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: 2002 sts engine codes
    kkucher is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2008
    4
    I have a 2002 STS, took it to Autozone and had them hook it to a computer. The car is sputtering, stalling, hard to get going and won't go very fast.
    These codes revealed themselves when hooked to the computer. P0101, P0404, P0420.
    Any ideas what these may becaused By? can I fix this myself? How much should it cost if I take to a dealership? I live in Metro Detroit area of Michigan. Thanks for anybdies help and this is a great site.
    FrankT's Avatar
    FrankT is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS
    Mar 2004
    Michigan
    61
    700
    Re: 2002 sts engine codes
    P0101 Mass Air Flow Sensor Performance
    P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
    P0420 Catalyst Catalyst System Low Efficiencey
    Fix the Mass Air Flow problem and EGR valve problem before proceeding with the P0420.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    you need
    A MAF
    A EGR Valve
    and a CAT
    a EGR and driving it while running like that failed the CAT, you melted it and clogged it
    your looking at at least 2 grand if you go for OEM parts
  5. #4
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Quote Originally Posted by CadillacSTS2003 View Post
    you need
    A MAF
    A EGR Valve
    and a CAT
    Woowa, slow down Jason.
    I would start by diagnosing the EGR first. An EGR valve that is sticking open will change the airflow and may cause a loss of vacuum that may also set the P0101 code or a lean code.
    You are correct about the damage that may have been caused to cat, a misfire is the worse thing to put a cat through, they hate it, I have heard some case where a misfire killed a cat in less than a minute. But, if not melted or broken up they can restore itself somewhat, though the life of the cat has been shorten.
    A restricted air intake duct
    A collapsed air intake duct
    A misaligned air intake duct
    A dirty air filter element
    A deteriorating air filter element
    Any objects blocking the air inlet screen of the MAF sensor
    Any debris or contamination on the sensing elements of the MAF sensor
    Any vacuum leak downstream of the MAF sensor
    A poor vacuum connection at the MAP sensor
    Any water intrusion in the induction system
    A restricted exhaust system
    All of the above can set a P0101 too. One thing at a time, diagnose and check circuits before replacing an expensive part. You also might want to try and clear all codes and see what comes back.
  6. #5
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,872
    The OP needs to learn to pull and read his own codes. You don't need to go anywhere: the car will do it for you. The instructions for your '02 are at the top sticky threads in N* performance and Tech tips.
  7. #6
    69
    82,286
    and
    I'd start by cleaning the EGR valve. Instruction are in the Tech Tips section.
  8. #7
    Oct 2005
    15,987
    hey im just basing it on the codes lol
    ESI confirms my diagnosis
    if the car wont run and has a SEVERE loss in power along with driveability issues and is throwing a CAT code along with an EGR code, my exhaust knowledge tends to say he melted the cat and it aint a cheap one on these cars lol
  9. #8
    Feb 2008
    4
    I have been given a quote for the, P0101, $295.00 with tax any idea if the car will run if this is replaced? It sounds like to me that it's a wait and see if I damged my CAT or not. Should I suggest that the Cad. service techs should clear the codes first or will the look at me strange of I suggest that. Thanks again for all the helpful suggestions.
    Mark
  10. #9
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Mark,
    Do to the fact that the car lacks power I would drop the exhaust just before the cat and see it the problem goes away, it's quick and easy. I don't think you have a bad MAF, If you had a bad MAF then after the P0101 set the PCM would will go to a default known good value and the car would run OK. A restricted exhaust system will set P0101, drop exhaust system and go from there.
    Like Jason said,
    I agree with that statment 100%
  11. #10
    Feb 2008
    4
    I took it the dealership, the service guy was very cool. He is replaceing the CAT under the warranty, there is something for GM to replace within warranty under 80k miles.
    They are going try to reset codes and go from there, they seemed very cool.
    Thanks for all the input guys.
  12. #11
    FrankT's Avatar
    Mar 2004
    Michigan
    61
    700
    Quote Originally Posted by kkucher View Post
    Now you are on the right track. I bet the Cat takes care of all three codes, and you are welcome.
  13. #12
    Crown Vic Owner is offline Cadillac Owners Connoisseur
    Automobile(s): 98 sls
    Aug 2007
    1,305
    good thing on the cat.
    Honestly, the EGR CAN NOT clog a cat AFAIK.
  14. #13
    Feb 2006
    56,872
    Crown Vic, A stuck/slow EGR valve causes a lean signal, among other things, from the downstream O2 sensors, driving the engine rich, which overheats the cat.
  15. #14
    Aug 2007
    1,305
    Quote Originally Posted by submariner409 View Post
    A bad EGR valve in these cars make the engine run RICH?
    Interesting. Most cars default to a default AFR that is not rich OR lean, just normal.
    this happens anytime the CEL is on i assume?
    So what happens if the CEL is on for something else, say, idk, TCC clutch?
  16. #15
    Feb 2008
    4
    Quote Originally Posted by FrankT View Post
    FrankT I see your from Michigan, where abouts? I live in Shelby Twp.
  • You may not post replies
