96 Eldorado ABS and Traction Control TRBL
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 96 Eldorado ABS and Traction Control TRBL in Cadillac Engine Discussion; Hello, 96 Cadi Eldo Shes displaying ABS and Traction Control lights. The lights are intermittant, but on more then off. ...
    thebossman's Avatar
    thebossman is offline Cadillac Owners Member
    Automobile(s): Cadillac 96 ETC
    Nov 2007
    31
    Question96 Eldorado ABS and Traction Control TRBL
    Hello,
    96 Cadi Eldo
    I used the on dash DTC feature and here are the codes.
    History:
    PC0111, PC0174, PC0603, PC1111, PC1406, PC1599, PC1626, IP2710, AC1348
    Current:
    PC0113, TC0027
    NO: SDM, RSS, PZM, IRC, RFA, CCP
    I used a DTC Codes disc, which I received with a scanner I purchased, I'm unable to locate the TC0027 code.
    Where do I go from here?
    John
    fubar569 is offline Cadillac Owners Fanatic
    Automobile(s): 82 fleetwood - 97 deville
    Feb 2006
    452
    Re: 96 Eldorado ABS and Traction Control TRBL
    based on going from list to list and OBD1 to OBD2 code lists and making an estimated guess i'd say that "0027" isnt really 0027...but any codes i can find with "27" in them point to a "left front wheel speed sensor" malfunction of some kind...either erratic signal or general fault.
    I'd start there
    also:
    P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage
    68
    81,927
    T027 ........................................ LF Wheel Speed Sensor Continuity Fault
    Replace the hub & bearing assembly
