intermittent Bubbling noise in dashboard.. Any ideas?
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, intermittent Bubbling noise in dashboard.. Any ideas? in Cadillac Engine Discussion; I am hearing a intermittent Bubbling noise in the dashboard upon acceleration. This 1998 seville sts has recently been timeserted ...
    ss6r is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac STS
    Jan 2008
    Saint Clair Shores, MI
    45
    19
    I am hearing a intermittent Bubbling noise in the dashboard upon acceleration. This 1998 seville sts has recently been timeserted and new OEM head gaskets and bolts replaced within 700miles ago. Symptoms are no overheating just bubbling in dash, could this be air pockets in the cooling system? is there a way to bleed the system other than through the pressurized coolant cap? Any help or oppinions would be greatly appreciated.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: intermittent Bubbling noise in dashboard.. Any ideas?
    Quote Originally Posted by ss6r View Post
    I personally pull a vacuum on the cooling system to remove all the air from it.
    It sound like air trapped in the heater core
    69
    82,162
    Do a search for purge line and check it. It's job it to purge the system of air so you don't have to.
    Jan 2008
    45
    19
    Thanks for your quick responses, I will investigate.
    Jan 2008
    45
    19
    Ranger I found this response from a post in december '07... thanks SS6R
    Ranger
    Cadillac(s): White Diamond '03 DHS Join Date: Jun 2004
    Casino Cash: $4991
    Re: 1995 STS Cooling problems?
    The purge line is the 3/8" line into the side of the surge tank near the top. It should spit coolant at idle and flow should increase with RPM. If you could not blow into it, that may well be your problem. Locate the obstruction and clear it. It may be where it connects to the water pump housing aka crossover manifold.
    Crown Vic Owner is offline Cadillac Owners Connoisseur
    Automobile(s): 98 sls
    Aug 2007
    1,305
    mind showing me where this line is?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,578
    Crown Vic, Take a look at the pic...the surge tank ('02 STS) is on the right and the purge line is the smaller hose which comes from the side of the tank, across the air intake pipe, and connects to the w/p-thermostat housing.
    Click on the image and scroll in. (Butt plug in there, too: intake resonator removed.)
    Aug 2007
    1,305
    Ah, ok.
    Thanks.
  11. Remove Advertisements
