Changing Coolant and the Right Number of Tablets - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
Northstar Engines and System Technical Discussion Discussion, Changing Coolant and the Right Number of Tablets in Cadillac Engine Discussion; Originally Posted by Ranger They are a cooling system supplement (sealant). The purpose is to prevent nuisance leak & seepage. ...
  1. #16
    mr_mr11 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac SLS
    Feb 2007
    44
    25
    Re: Changing Coolant and the Right Number of Tablets
    They are a cooling system supplement (sealant). The purpose is to prevent nuisance leak & seepage. They can be purchased at any GM dealer or Walmart, or most parts stores. If you get them from other than a dealer look for Barsleaks products. The tabs product code is HDC and the powdered version is G12BP. Put them in the radiator hose, NOT the surge tank. Do a search for Barsleaks, tabs, cooling system supplement, HDC, G12BP. You should find enough reading to keep you out of trouble for days.
    Ranger, when I was at my local parts desk at the Caddy dealer last week picking up a water pump, I asked them about installing the pellets. They told me that they no longer put them in N* engines b/c they tend to clog up the radiator? They also no longer carry them in stock for sale. Any truth to this notion? mr_mr11
  2. #17
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by mr_mr11 View Post
    ....they tend to clog up the radiator?....
    Not so.
    The proper material installed properly will not clog the radiator. The tablets or powder is only an insurance policy protecting you from minor nuisance leaks.
    You decide.
  3. #18
    69
    82,381
    If that were true, all the earlier Northstars plus the 4.9's, 4.5's & 4.1's would have clogged radiators and we would certainly have heard complaints here. I think the reason that they quit using them is because they make the coolant look muddy, thus people where complaining that the cooling system is going bad and asking that the coolant be changed while under warranty. Especially if they have been on the internet and were reading Dex-Cool horror stories.
  5. #19
    Mountie's Avatar
    Mountie is offline Cadillac Owners Enthusiast
    Automobile(s): '93 STS (sold), now looking for a CTS Wagon soon!!
    Jul 2005
    Bradenton, Fl
    62
    502
    I replaced my North*, and refreshed everything. Just a little suggestion about installing your waterpump. ( You can do it yourself ).... When using that special socket installing the waterpump, & as you turn it to lock it in place, notice the bent-up tabs...... They will flatten very easy, if you use a breaker bar!! Careful not to go to tight, to the poing you flatten the tabs, and 'spin' the waterpump past the stops. I was told to use just grease at the '0' ring area, and it's to keep the pump from corroding / rusting.
  6. #20
    Feb 2007
    44
    25
    Quote Originally Posted by Mountie View Post
    Mountie - I echo your comments on the water pump replacement however I had to use an impact wrench to get my old one off and get the new one back on - the handy socket I purchased from Napa worked well.
    Thanks to all for the good posts!! mr_mr11
  7. #21
    26TP's Avatar
    26TP is offline Cadillac Owners Fanatic
    Automobile(s): 99 STS 2002 STS
    Mar 2007
    London
    56
    110
    Apologies for what might seem like a dumb question,
    After draining all of the old coolant, should you flush cold water through the system to remove any old coolant deposits?
  8. #22
    69
    82,381
    No. You never get all the old coolant out, so I you flush it, you won't get all the water out. Then you'll have to use a refractometer to get the correct 50/50 mix.
  9. #23
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Mountie's warning is correct....I know....
  10. #24
    26TP's Avatar
    Mar 2007
    London
    56
    110
    Great, thank you very much to all who replied for your help.
    And finally is the 50/50 mix rule super critical?
  11. #25
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by 26TP View Post
    ....And finally is the 50/50 mix rule super critical?
    It's important enough to put some effort into measuring carefully if you are doing the mixing.
    Not only does the Dex-Cool provide freeze protection. It also elevates the boiling point of the mixture. And you really want the boiling point of the mix to be in the neighborhood of 265 degrees F @ 15 PSI pressure. If you end up with less than 50% Dex-Cool and more than 50% water, the pressurized mixture will vaporize at less than 265 degrees F @ 15 PSI. How much less won't matter when you are stranded on the side of the highway some dark and stormy night.
    It might seem super critical at that point.
  12. #26
    racinrod67 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Seville STS
    Feb 2008
    Pensacola, FL
    229
    I picked up some cooling system seal tabs from the dealer today, part #3634621. I plan on putting all 6 tabs in the system along with fresh 50/50 Dexcool mix. I understand not to flush the cooling system with fresh water, just drain and refill, correct? One other question, the parts guy and the package instructions say to crush up the tablets, add to the coolant and pour directly into the radiator, so is that the best way, mix and pour into the surge tank?
  13. #27
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    49
    2,759
    Quote Originally Posted by racinrod67 View Post
    You may want to look at this
    #51
  14. #28
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    racinrod, If your manual calls for the cooling system tablet supplement, it generally specifies 3 tablets crushed in the lower (return) radiator hose. Using the whole package is unnecessary overkill and could very well lead to clogging of some cooling passages.
    As AJ's lengthy thread (referenced above) says, the supplement tablets were and are not designed to be a cure or preventative for head gasket gas leaks into the coolant; rather they were used to seal nuisance weeps from gasket irregularities and aluminum casting pososity. General Motors is not the only engine manufacturer to use the product, not by a long shot.
    Drain as much old coolant as possible and refill with a 50/50 mix of the coolant specified in your manual.
  15. #29
    69
    82,381
    They need to be crushed when putting them in a radiator because of the oil or trans cooler line in the side tank. That prevents you from putting whole tabs in there. On the Northstar you can just pop the whole tab in the radiator hose.
  16. #30
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    70
    962
    Upper hose will do - NEVER in the surge tank. K_C
  17. Remove Advertisements
