Starts fine when cold, hesitates when warm...
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Starts fine when cold, hesitates when warm... in Cadillac Engine Discussion; In the morning my 97 Deville cranks up fine. It just hit 90k miles the other day. When it hesitates, ...
    Wicho is offline Cadillac Owners Fanatic
    Jan 2004
    Miami, Florida
    134
    In the morning my 97 Deville cranks up fine. It just hit 90k miles the other day. When it hesitates, after I smell a slight sent of gas but leaves after about 15 seconds. I took it to a small auto shop and they couldn't find anything. I would also like to know how to erase all the code on the computer so I can see what going on now. A friend of mine said that the Cadillacs store all the codes since the day they are manufactored. Is this true and if so how do I erase the codes ? Thanks
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: Starts fine when cold, hesitates when warm...
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Codes are NOT stored since the day the car was built....LOL...if a code sets it will turn on the SES light as long as it is current..i.e..the onboard diagnostics system is detecting a failure currrently. If the code is not longer being detected the code reverts to a "history" code that is stored for 50 ignition cycles and then it erases if it isn't showing up or being detected any more.
    Jan 2004
    Miami, Florida
    134
    Wow... thank link helped very much, thank you ! Bob, thanks for setting the story straight. I was thinking the same thing you said but he kept on insisting so I just gave in and belived it
    BeelzeBob's Avatar
    Dec 2002
    52
    9,577
    Check the fuel pressure regulator and/or replace it. Most likely cause of the complaint you have. Lots in the archives...search using "fuel pressure regulator" or "FPR"....
  8. Remove Advertisements
