1996 Deville Troubleshoot update
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 1996 Deville Troubleshoot update in Cadillac Engine Discussion; Took the deville to my mechanic. His read out came back first bank O2 sensor. Took that out really dirty ...
    orangeman is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    14
    Took that out really dirty cleaned it put it back in.
    Took out egr not sticking or really dirty so cleaned it anyway and put it back in.
    Cleaned Idle control.
    Cleaned air filter not really dirty either.
    Added some injector cleaner.
    When I left Emmisions light went off which is a good thing.
    Got it home left it to idle.
    Stopped after 10 minutes.
    What was that throttle body cleaning you mentioned Ranger?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,904
    Re: 1996 Deville Troubleshoot update
    Try this: Google "cadillacforums.com+deville+throttlebody" and see what happens. If no joy, use the search function in the top ^^ bars as well as read the technical archive.
    There is so much info on TB cleaning in here that you'll need a ream of paper to print it all out.
    68
    81,922
    As Sub said, check the Tech Tips section. I think there is a tutorial on how to clean it. If it is a '96 and has never been done, you'll be surprised at how filthy it is and will take some scrubbing. Doing it once a year will make it much easier. I do mine every spring.
    Jan 2008
    14
    OK that's next I guess Thanks Guys for your help will let you know if that works
    Jan 2008
    14
    OK throttle body cleaned no change except I have felt it surge at a stop once.
    If the o2 sensor on the 1st bank was cleaned should it be hooked up again to see if any of the other o2 sensors register or should I just have them all cleaned anyway?
    I just know this has to be something simple the car runs way too good. Maybe I should change the fuel filter also?
    68
    81,922
    I don't think O2 sensors are meant to be cleaned.
    Jan 2008
    14
    So I guess I'll replace it..maybe I'll replace them all.. I'll let you know
  10. Remove Advertisements
