Results 1 to 14 of 14
Thread: Missed one connection
    442JoeRed is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2007
    14
    I replaced my engine in a 97 Seville STS. I am missing one connection that goes to a white an blue female connection. The connection is under the master cylinder. Can anyone tell what is suppose to go there? Everything else is done.
    Thank you,
    Joe
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Missed one connection
    is it a two wire?
    is it just like the one on the right side near the strut tower and heater hoses?
    if it is not a two wire how many terminals can it take and how many does it have?
    Picture?
    Sep 2007
    14
    Good to hear from you. You have helped me before. It is a 2 terminal. I have attached a photo.
  5. #4
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Is the left front wheel speed sensor hooked up?
  6. #5
    Sep 2007
    14
    I'll look. Was thinking it may be that and the connection fell down somewhere. Replaced the engine going through the top. Not that bad. A lot faster if I would need to do it again.
    Thank you,
    Joe
  7. #6
    BigJon's Avatar
    BigJon is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 El Dorado
    Jun 2007
    Center Line, Mich
    28
    697
    let me get this correct you pulled the north star up? if so how did u do that?
  8. #7
    Sep 2007
    14
    Pulled radiator, ac condensor, intake, Exhaust y pipe, disconnect torque converter, remove transmission bellhousing bolts, etc.
    Not that bad, just takes time the first time. A lot quicker if I needed to do it again. The hardest part was removing all the brackets on the rightside of the engine to the transmission. Need a cherry picker and good lifting devise to balance engine.
    Joe
  9. #8
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    and you pulled the hood too id assume correct?
  10. #9
    BigJon's Avatar
    Jun 2007
    Center Line, Mich
    28
    697
    it seems easier to drop it from the bottom the other reason i have not done mine because it been cold out and i dont have a garage to do it in and i was told if i used a cherry picker to lift the body it will bend... i dont not if that true but w/e
  11. #10
    Sep 2007
    14
    Yes, I pulled the hood also. I work in a garage that will get down to about 40 degrees. Turn on a tv or radio and it's actually pretty comfortable. Just started the thing and this engine has the same head gasket issue! The engine was pulled out of totalled DTS. Back the the wrenching. Already have the headsert tools. Will be a lot quicker this time around. I have attached a pdf with how to remove from the top.
    Joe
  12. #11
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    DTS started in 2000 and had the new design Northstar with roller followers - yours is a '97 - older design - I thought that was a problem, no?
  13. #12
    RickyHenry's Avatar
    RickyHenry is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville; 1999 Seville
    Mar 2008
    134
    are you saying you timeserted your previous engine, then had to get a new engine after you had already done the hg job on your first one?
  14. #13
    99_concours is offline Cadillac Owners Member
    Apr 2008
    12
    I quickly perused the engine rebuild pdf and noticed it is to a '95 'Y' engine; mine is a '99 '9' engine (300hp). Are the procedures outlined compatible? Does this look like an acceptable way to remove the engine? With my garage configuration (small, two-car with single-car overhead doors and exactly 20' deep and 9' wide each bay...ugh!!!) it may be the wiser choice. I simply don't have the working room around the car to remove the engine underneath with cradle and all...
    2nd question; with the hood off and the radiator, accessories, etc. disassembled and out of the way is there any way the engine could be timeserted while still mounted in the engine bay (without complete removal of the engine)? Seems to me that if there is a way to timesert it while the car still 'holds' the engine in place and without the complete removal that would be ideal, however, I do understand everybody is dropping (or in 442JoeRed's case lifting) the engine for this work.
    Last question: 442JoeRed, your screen name sound Oldsmobilean to me...if so, I have an '85 Olds 307 that I am about to replace with a '79 TransAm Olds 403...any suggestions? (I know this is a Cadillac post...) I am wondering what headers would work or are available to work in a 2dr Delta 88 Royale Brougham platform with the 403 at the very least; plus I need a dual exhaust crossmember from a pre-'75 model to modify and fit to the '85.
  15. #14
    RickyHenry's Avatar
    Mar 2008
    134
    I'll take an educated guess and advise that it's the connection to the hood.
  • You may not post replies
