Those Damn HEAD GASKETS
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Northstar Engines and System Technical Discussion Discussion, Those Damn HEAD GASKETS in Cadillac Engine Discussion; Has anyone had any luck with any kind of head gasket sealant for the northstar engine. Or Im just out ...
    99 eldog's Avatar
    99 eldog is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    14
    engine. Or Im just out of $5000.00 to have them replaced? Help me please
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: Those Damn HEAD GASKETS
    omfg
    dude
    S E A R C H
    nothing will seal a LIFTED head
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,208
    The sealants don't work for more than a short while. $5000 for a repair is a bit high. There are quite a few forum members that have repaired the cars themselves. There is sufficient information right here on the forum for an advanced amateur to do the job. Good luck!
    Don't mess with Binky Bear!
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Seal in a can is a waste of time and money.
    There are shops that have done them and will do a good job for less. Please list a general location so someone can give a referral if there happens to be one.
    JC316 is offline Cadillac Owners Connoisseur
    Mar 2005
    DFW Texas
    30
    1,406
    Sealant won't help you, especially if the threads pulled loose.
    flyinlow is offline Cadillac Owners Member
    Automobile(s): Custom mid engine Mclaren w/twin turbo northstar in process
    Jan 2008
    Spring Creek NV
    35
    You can put a bunch of sealer in it , then you will will get to replace the heater core and possibly radiator at the same time as the head gaskets and inserts.
    Sorry for the sarcasm but sealer wont help
    99 eldog's Avatar
    Jan 2008
    14
    Thanks for the help. The dealership quoted me $5900
    Anybody know of any machanics in the detroit area?
    99 eldog's Avatar
    Jan 2008
    14
    this is my first cadi i am not very much of a mechanic. And i hear that you can run into all kinds of difficulty
    with this repair. head bolts pulled and so forth.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Take a look at www.rhinoengines.com and click on "specials-specials" in the left menu.
    Check with your local shop and do some homework to find out if a 2000 engine will fit your 99. Someone will chime in here....you may get lucky.
    ss6r is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac STS
    Jan 2008
    Saint Clair Shores, MI
    45
    19
    Eldog I am from Detroit and I am timeserting(Head bolt repair) my 98 STS engine as we speak. I am not a professinonal mechanic but have some experience wrenching. Your quote for the repair is much better than I got, i was quoted $7500 from Don Gooley Cadillac/detroit. This is my second engine, and the first attempt at timeserting a block. Honestly so far not a difficult job, but very time consuming. As for mechanics, I found one mechanic from Jeffrey Buick in detroit that would do it for $3500. All others said they were not interested. I did find a 100,000 mile northstar for $400, the guy sells cadillac parts and it was one of three and he wanted to unload it to make more room. I passed on it 2 weeks ago, because I didn't want to put the engine in and have the same problem again. That engine might still be available I believe it was from a 98.Timeserting the block with new head bolts/gaskets and the newest torque settings from what I have heard seems to fix the weak link for a hige mileage northstar.
    The best deal I found for a remanufactured engine was ACCURATE ENGINES in Grandville, Michigan. $3495 for a 4.6 CADILLAC NORTHSTAR ENGINE w/ a 3 year unlimited mileage nationwide warranty. Here is a link to there northstar page http://www.ae-engines.com/cadillac46northstar.html or main page is http://www.ae-engines.com. Hopefully some of this info helps ease the pain.
    99 eldog's Avatar
    Jan 2008
    14
    Thanks for you guy's help!
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    That sounds high to me too. I've heard numbers more like $3500 to do HG job. No?
    99 eldog's Avatar
    Jan 2008
    14
    Hey I Tried Themagasket Today And It Seems To Be Working. No Leaking Coolant No Hi Temps Check Engine Light Went Off. The Stuff Looks Like It Works For Now
  16. #14
    99 eldog's Avatar
    Jan 2008
    14
  17. #15
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,208
    Good luck! One guy got it to last around a thousand miles before it let go.
  18. Remove Advertisements
