Difference between VIN Y and VIN 9
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Northstar Engines and System Technical Discussion Discussion, Difference between VIN Y and VIN 9 in Cadillac Engine Discussion; Can Someone Tell Me The Differences In The 2 Engines From A 96 - 99 Eldorado Or Seville...
    allpro1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    1
    QuestionDifference between VIN Y and VIN 9
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: Difference between VIN Y and VIN 9
    Y runs around 275 advertised HP. 9 about 300. Cams and PCM/management tuning, but NOT a simple swap. Take a long read in the N* PCM tuning forum (many pages.....)
    The Y torque comes in at a lower range than the 9. Y is suited for the traffic light set while 9 appeals to the long haul high speed driver.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Y engines have 275 hp and 300 tq. Also have a 3.11 final drive ratio. 9's have 300 hp, and 295 tq. Also have a 3.71 final drive.
    Don
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    In the 96 to 99 engines the Intake Cams are the only mechanical differences.
    The tranmissions are different from a Y to a 9 application. The biggest part is the final drive gear ratio. 3.11 vs 3.71
    The PCM program is different on many levels. Too much to go into
    68
    81,887
    The "Y" engines will obviously deliver a little better mileage due to the lower final drive ratio.
    dhm37 is offline Cadillac Owners Member
    Automobile(s): 96, 98 STS
    Sep 2005
    79
    29
    The Intake Cams are higher lift in the 9, and the valve springs are stiffer for both intake and exhaust valves. As far as I can tell, the valves are identical for both 9 and Y.
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by dhm37 View Post
    The spring are the same except in 93 and maybe 94. after that they are the same
    FRAN_Astur is offline Cadillac Owners Member
    Apr 2008
    6
    How can I identify wich of them is each? Where can I look for to know if a engine is from a VIN Y or a VIN 9 car?
    Thanks.
    Feb 2006
    55,840
    Take a look at your VIN. The 8th character will be a 9 or a Y. The engine itself also has a "VIN derivative" stamped in a pad on the lower right front side of the block.
    Otherwise, read the Northstar Performance threads, go back a month or so and find AJxtcman's posts on Northstar cam numbers. It's all in here, somewhere.
    Apr 2008
    6
    Thanks for the reply, I ask becouse a friend bought a 98 STS with a hard knock in the engine ( I think it could be a rod), and he found other 97 northstar engine and bought it for the STS, but we don't know anything about the vin of the donnor car, so, this is why I ask. We allready have the engine, and don't find any to identify this other engine. I also must say that when he bought this engine, we was thinking that all northstar engines were equals, less little changes over years.
    I think you don´t need that I say that I am new in cadillacs. My other cars are a 91 Trans Am and a 73 Camaro.
    68
    81,887
    If you have the right VIN, '97 & '98 should be compatible.
    Bolo's96STS's Avatar
    Bolo's96STS is offline Cadillac Owners Member
    Automobile(s): 99 Cadillac STS
    Dec 2006
    Central Ohio
    35
    51
    Quick question, would a Vin 9 1994 swap with a Vin 9 1999? Both are STS's
    97EldoCoupe's Avatar
    97EldoCoupe is offline Cadillac Owners Connoisseur
    Automobile(s): 97 ETC x2, 04 GXP, 04 STS x2, 97 ESC, 99 Deville, 05 SRX
    Mar 2007
    London, Ontario and Winkler MB
    31
    2,618
    The 94 will have different heads, which will need some modification, and there's a bolt hole for the RH engine/trans mount that will be non-existent on the '94, and you will need to drill & tap a hole for the knock sensor between the #3 and #5 cylinder under the intake. I'm sure I could think of other little issues but you'd be better off starting with the correct year engine. It can be done though.
  16. #14
    68
    81,887
    '94 is OBDI. '99 is OBDII.
  17. #15
    Mar 2007
    31
    2,618
    Yes it is OBD1, but if you use the 99's intake plenum & TB, you've already taken care of most of the sensors. I believe the CKP/cam pos. sensors are the same from 93-99, and so is the crankshaft reluctor wheel. The only thing you would have to do is relocate the mounting for the knock sensor and use the '99's, because in 1996 the knock sensor & its location was revised. Oil level and pressure sensors I'm not 100% sure but they can easily be transferred.
    The issue is the "cuts" in the intake ports. This would pose a serious vacuum leak if they weren't filled up prior to bolting down a 95-99 intake plenum. JB weld or something similar would do the trick, provided that what ever you use, would never break loose and fall into the ports.
  18. Remove Advertisements
