Got Code P1415 Please Help
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Got Code P1415 Please Help in Cadillac Engine Discussion; Hello everyone, I'm new to the board. Can anyone help me with this code P1415 on a 2002 Deville DTS....
    jfrench830 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    3
    ExclamationGot Code P1415 Please Help
    FrankT's Avatar
    FrankT is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS
    Mar 2004
    Michigan
    61
    700
    Re: Got Code P1415 Please Help
    Hello, jfrench830 and welcome to the Cadillac Owners Forms!
    P1415 is Secondary Air Injection System - Bank 1, which is the rear bank of the engine.
    Here's what you do, test the rear SAI shut off valve with a vacumm pump, the valve should hold vacumm and open when 10" of vacumm is applied. The diaphram in the valve is a common failure. Another thing that could be wrong is the vacumm line that goes to the shut-off valve could be loose, cracked, or plugged. The vacumm soruce to the valve comes from a solenoid under the engine cover, a lot of times the vacumm line gets knocked off during other engine repairs.
    Let us know what you find.
    Frank
    Jan 2008
    3
    Thanks for responding, I am mechanically inclined, but I've never just inspected all up under my hood b4. Exactly where are these things you are speaking of.
    69
    82,381
    It is on the rear cam cover. Since you are mechanically inclined and do your own work a FSM will be worth its weight in gold. Ebay is your friend.
    Jan 2008
    3
    Sorry about getting back so late but the problem was I had an intake leak. Thanks for all the help!!
  8. Remove Advertisements
