2000 Deville with northstar
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 2000 Deville with northstar in Cadillac Engine Discussion; A friend of mine has asked me if I would change the valve cover gaskets in his Deville. I was ...
    Wally Banger is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    1
    I was wondering if anyone could give me some info on how it is done or would he be better off going to the dealer.
    Thank You
    68
    82,082
    Re: 2000 Deville with northstar
    The Left bank (front) cam cover has a water pump drive pulley attached to the intake cam, so you need a puller to use a P/S pump pulley remover/installer to get it off in order to get the cover off.
    The right bank cam cover (rear) is very close to the firewall. Not sure if there is enough clearance. You may have to lower the cradle.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Ranger. You're confusing me now with the left right front rear thing. This is the way I thought it was but in that other thread you stated the opposite.
    68
    82,082
    What other thread? Maybe I need to correct something. Can't imagine I screwed THAT up.
    Engine faces the passenger side so left bank is closest to the front of the car. Right bank is closer to the rear or firewall.
    EDIT:
    Just found and corrected it. Sorry for the confusion.
  7. Remove Advertisements
