Where is the main engine to body ground?
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Where is the main engine to body ground? in Cadillac Engine Discussion; I am almosted finished with the engine install on my 99 SLS. I have run into a couple snags though. ...
    mpe331lx is offline Cadillac Owners Member
    Automobile(s): 99 SLS
    Sep 2007
    Florida
    43
    I need to know the factory points where the ground strap goes from the engine to the body/chassis.
    I know that I could bolt it anywhere, but I would like to keep it as close to OEM as possible.
    I also need hep finding a replacement heater/coolant tube, here is a link to that thread:
    http://www.cadillacforums.com/forums...e-98-99-a.html
    Any help would be greatly appreciated.
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Where is the main engine to body ground?
    Quote Originally Posted by mpe331lx View Post
    The ground cable on the 98 to 04 is in the same location.
    It runs from the upper alternator bolt to the frame near the Under Hood Fuse Box
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,202
