north swap
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, north swap in Cadillac Engine Discussion; I just like to know if a 94 eldo north could replace a 96 deville northstar. and if not what ...
    PhillyCaddy's Avatar
    PhillyCaddy is offline Cadillac Owners Fanatic
    Automobile(s): 1994 SLS
    Aug 2003
    Philadelphia Pa
    43
    143
    north swap
    I just like to know if a 94 eldo north could replace a 96 deville northstar. and if not what would it take to do so.
    DaveC is offline Cadillac Owners Member
    Jun 2003
    Texas
    17
    Re: north swap
    94 intake manifold /head interface is different from 95/99. 95/99 NS would be the way to go. Need to use the intake manifold/throtle body from the 96.
    DaveC
    Aug 2003
    Philadelphia Pa
    43
    143
    Re: north swap
    I have a 96deville with blown heads and have 94 eldo wreck with good engine. this is why I ask. just trying to make things work if possible.
    If I swap intakes would that work.
    Jun 2003
    Texas
    17
    Re: north swap
    96 intake will not work on the 94 engine. I'm not completely sure on this but I don't think the 96 wiring harness will work with the 94 intake. Maybe someone else can help on that issue. Also fuel rail connections could be a problem.
    Lawrence's Avatar
    Lawrence is offline Cadillac Owners Fanatic
    Oct 2003
    Ohio
    334
    Re: north swap
    Search for user "dloch". He is doing the same thing. You have to add holes to the 94 heads to use the 95+ intake, among other things.
    dloch is offline Cadillac Owners Fanatic
    Mar 2004
    Michigan
    172
    Re: north swap
    You can't just swap the intakes from 94/95 to 96/97 engine. Here are the links to the information you are looking for. If you have any other questions I think I can help you out as I have done this... and you will have to have to drill and tap some additional holes, close the others but it can be done. I used the intake itself as a guide to do the drilling and longer than normal drill bit. You will also need to use a .409 drill bit to open the end holes since the intake gasket uses them as locating spots.
    The electrical issue I can't answer just yet as I'm not quite that far yet. As a far as the fuel rail and the location of the connections some are different, it depends on what car the engines came from and are going into although you can swap that stuff from one to another, not a big deal.
    http://www.cadillacforums.com/forums...ad.php?t=11408
    http://www.cadillacforums.com/forums...8849#post88849
    http://www.cadillacforums.com/forums...ad.php?t=11015
    Like said if I can help you out let me know.
    Aug 2003
    Philadelphia Pa
    43
    143
    Re: north swap
    well I just might be parting out the 96 deville if all that must be done. not sure yet. or maybe I might just do the head gasket. I rather not play to much with them.
    Thank you all for the info.
    If I part out, I will let you all know.
  10. Remove Advertisements
