1994 DeVille Concourse
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, 1994 DeVille Concourse in Cadillac Engine Discussion; Appreciate your help: I have a 1994 DeVille Concourse w/a blown head gasket? It overheats in about 15 minutes, coolant ...
    cadijunkie is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    3
    Appreciate your help: I have a 1994 DeVille Concourse w/a blown head gasket? It overheats in about 15 minutes, coolant reservoir smells like exhaust when I open the cap. I have a good running donor car 1996 deville, hit in rear. Was told I can't use the 1996 Northstar in a 1994? Comments?
    Florian's Avatar
    Florian is offline crushing Vs with my Wurm
    Automobile(s): 2013 GT500 - 700+ HP
    Aug 2003
    location, location
    12,266
    Re: 1994 DeVille Concourse
    Im not the mod for this forum, Junk, but all technical car specific Qs need to be put into the proper forum so that all can benefit from the replies. This post should go into the Deville forum.
    F
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    I'll go ahead and move this to the appropriate forum for you. And
    68
    81,913
    I don't think you can use it. '94 is OBDI and '96 is OBDII. You can swap a '93 or '94. '95 would work I believe if you swap manifolds.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    No. OBDx is irrelevant. 1995-1999 will swap, other than the throttle body on the 95, which adds a throttle closed position switch. 1993, 1994 have a different EGR setup and will not work. The 94's engine has EGR passages machined into the head ports, the 1995+ does not. The 1994 has a whole EGR manifold plate thing, the newer engine does not.
  8. Remove Advertisements
