P0741 TCC Stuck ON, tried much, what next
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, P0741 TCC Stuck ON, tried much, what next in Cadillac Engine Discussion; There is a great deal of posts out there on the famous P0741 Code. I have followed as many as ...
    whitediamond96 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2007
    There is a great deal of posts out there on the famous P0741 Code. I have followed as many as I can find. Here is what has been changed on my 96 deville.
    Torque Converter, Reactor seals and bearings, TCC Sol, Pressure Sol, Turbine Shaft seals (they were bad) and bearings, Filters, Fluid.
    Code is still there. But, mostly up a slight hill over 41mph in OD.
    I will check for actual slippage number later.
    Can anybody help with how the Brake Switch would cause the code?
    Haven't tried the Sonnex reamer and seal yet (can't find the post again!!!) Help.
    Anybody have any other thoughts?
    69
    82,287
    Re: P0741 TCC Stuck ON, tried much, what next
    The brake switch deactivates the TCC. Otherwise it would be like trying to stop a standard trans without stepping on the clutch.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    I think there is a reprogramming available that helps.
    Dec 2007
    Thanks Ranger and Zonie77.
    This is all very frustrating.
    As for the brake switch. What I should have said is can anybody figure out how a Brake switch would cause the code to set. I even tried driving up the hill that always sets to code while holding the brake pedal back (just in case the pedal switch was on the harry edge) still received the code.
    Zonie77 - re programming that interest me... Anybody have some details?
    69
    82,287
    I think you can rule the brake switch out. See what Zonie says about the reprogramming. I seem to recall something about that. Maybe Ewill or AJ will chime in.
    Sep 2003
    Arizona
    3,531
    I haven't had this problem so I'm just putting out something I remember. I'm pretty sure there is a revised program.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    It's not your brake switch if this happens in uphill driving.
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    If you can find AJ, he is much better with transmissions than I am.
    I can tell you more info. I specialize in a different area, it has been a while since I have done any trans work.
    LCLCLC is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville
    Mar 2004
    244
    Isn't 741 the 'nasty' code that requires removal and dis-assembly of the tranny get to the lock-up solonid?
    The other 'A' and 'B' shift solonids can be changed without pulling the tranny, but do not set the 741 code. I think.
    69
    82,287
    Yes, but it does not have to be done. It can be lived with.
  13. Remove Advertisements
