Mobil 1 5W30 meets GM spec 4718M but Mobil 1 10W30 DOES NOT. WHAT GIVES?
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, Mobil 1 5W30 meets GM spec 4718M but Mobil 1 10W30 DOES NOT. WHAT GIVES? in Cadillac Engine Discussion; Was buying gallons of Mobil 1 5W30 at Wally World at $21.95 for a 5 quart container. Also have a ...
    bighank is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    31
    Was buying gallons of Mobil 1 5W30 at Wally World at $21.95 for a 5 quart container. Also have a newly acquired 1999 Cadillac DeVille which takes 10W30 when the sustained temperature is over 50 degrees F.
    Looked at both containers.
    Mobil 1 5W30 says it meets GM spec 4718M.
    Mobil 2 10W30 DOES NOT
    Cadillac recommends the heavier viscosity oil in the Northstar engine.
    Why doesn't the Mobil 1 10W30 meet the same specs as their 5W30.? BIGHANK
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,849
    Re: Mobil 1 5W30 meets GM spec 4718M but Mobil 1 10W30 DOES NOT. WHAT GIVES?
    Cadillac does not specifically recommend 10W-30 (the heavier oil) in all Northstars.
    Your engine might be spec'd for 10W-30 above 50 degrees, but 2000 and later are spec'd for 5W-30, same temperature.
    Like ILSAC specs, GM specs vary with the seasons or barometric pressure .
    ........And, in 2000, one running change was from "flat tappet" style cam followers to rollers, allowing lighter cold oil viscosities as well as accomodating the slightly reduced zinc/phosphate load in newer oils.
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    49
    7,531
    My mom and dad used to run Amsoil 0W30 in their N* (97 Deville) and after long trips the next day it would rattle like the engine had no oil in it. After 3-4 towings to the dealer (under warranty) GM's answer was changing the oil.... No definitive answer.
    So I told my dad to run Amsoil 10W30 in. Never and issue since.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    There are no 5 quart containers. One gallon is four quarts. $21 Mobil1 bottles have four quarts.
    I've had decent luck with Mobil1 0w40, no rattle or valvetrain noise. No tappet or cam wear either, I've seen them closely.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    Quote Originally Posted by Zorb750 View Post
    I'm afraid that's incorrect. Most oil's come in 5 qt containers. The diesel
    oil's do come in 4 qt though like Rotella, which I now use.
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    I second that, I buy exactly that bottle for my 94 FWB.... 10W30 EP.... That or Rotella T 5W40 for the extra ZDDP it has....(1400 ppm in the CI-4-Plus formula)
    Apr 2005
    Oakland County, MI
    33
    1,320
    Why do I have two four quart/1 US Gallon containers from Mobil1 in my garage?
    clarkz71's Avatar
    Mar 2006
    53
    1,357
    Pictures don't lie, you can see the picture can't you, it say's " 4.73 liters/5 US quarts".
    You said "it doesn't come in 5 qt containers".
    N0DIH's Avatar
    Aug 2004
    Rockford, IL
    49
    7,531
    They market 4 and 5 quart, depending on the grade/type. Go take a trip to Walmart and look. They carry both. Maybe it is a larger store thing. The 4 quart ones aren't a good buy, the 5 quart typically are much better. As with a 4 you have to buy one individual and that is pretty expensive in comparison to the 4 or 5 quart price.
  12. Remove Advertisements
