What Spark Plugs for a 1999 DeVille Northstar?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, What Spark Plugs for a 1999 DeVille Northstar? in Cadillac Engine Discussion; What plugs should I use in a 1999 Northstar engine. Owners manual says Delco 900. Haynes manual says Delco 950. ...
    bighank is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    31
    What plugs should I use in a 1999 Northstar engine. Owners manual says Delco 900. Haynes manual says Delco 950. Think both of these are platinum.
    My LS1 NOW USES IRIDIUM plugs in place of the old platinum plugs originally installed. Old plugs had hockey pucks on the electrode which would "fall off" and get ground up by the pistons. How much hassle is it to change them?BIGHANK
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Re: What Spark Plugs for a 1999 DeVille Northstar?
    I would have said go with the Caddy manual but the AC Delco site agrees with Haynes for your car.
    http://198.208.187.182/internet/Vehi...e=25&part=7212
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    ac delco PERIOD
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,215
    The new series "Professional" ACDelco double platinum plug listed for your car is #41-987, $5.05 or so from www.rockauto.com.
    There are a skrillion words in here on spark plugs, and if you read them all you'll stick with the Delco.
    Gap .050, torque cold to 11-13 ft/lb.
    TexasCadillac Guest
    Quote Originally Posted by bighank View Post
    I was wondering why my 98 Deville manual says to use Delco 900 spark plugs and the ones I just changed were Delco 950 plugs and the ones I took out were 950 also. Which one is the hotter plug and which is best to use? The 950 seem to work fine. TexasCadillac
    68
    82,064
    I am not positive, but I would guess that the 950's superceed the 900's. I think I used 950's in my '97.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    41-950 is what mine had.
    I use Denso plugs, I find them to do quite well, 40K so far. NGK will be fine too. The only non ACDelco plugs that really cause problems unless you buy junk (Champion basic, Autolite (even platinum), or any copper plug), are Bosch's platinum plugs which seem to be thermally incompatible with a lot of GM engines.
  10. Remove Advertisements
