Crank sensor tech 95 sts
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Crank sensor tech 95 sts in Cadillac Engine Discussion; Does any one have the spec on the crank sensor Or a pic number of teeth I assume it a ...
    STSforfun is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2007
    43
    Does any one have the spec on the crank sensor Or a pic number of teeth I assume it a magnet pick up? Who make the senor?
    Craig
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: Crank sensor tech 95 sts
    New series of CKP is made in Japan, spec'd by GM Engineering. 2 sensors in later N*'s. Hall effect sensor creating square and sawtooth pulses from a large reluctor machined on the crankshaft......I think 100 + teeth in the main wheel, also cut with a smaller odd number of teeth in order to give correct cylinder number reference and timing if either sensor goes bad. If so, PCM defaults to fixed timing and sets codes.
    Quite a bit of info and many pictures in here earlier this year. Search.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    All Northstars have 2 crank position sensors (CKP)
