so i got a few PCM codes
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, so i got a few PCM codes in Cadillac Engine Discussion; I got some circuit codes, but i have P1617 - Engine Oil Level Switch Circuit P1520 - Transmission Range Switch ...
    Crown Vic Owner is offline Cadillac Owners Connoisseur
    Automobile(s): 98 sls
    Aug 2007
    1,305
    P1520 - Transmission Range Switch Circuit
    The first one, that is to tell how high the oil is, right, aka it wont go off if its low?
    And the second, what the hell is that
    the motor was changed in this car, i know that.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,385
    Re: so i got a few PCM codes
    Those are news to me too .
    BTW, I don't think changin the engine has anything to do with those codes .My car's engine was replaced too yet never seen such codes .
    Aug 2007
    1,305
    i mean, its probobly my dads f*** up.
    He installed the engine, and i know the trans guy at the shop did some "teaking" to it, and i know he knows his shit.,
  5. #4
    Dec 2003
    36
    4,385
    I didn't like "teaking" thingy I must admit . I presumed the engine was replaced by a dealer .So may be some solenoid problem might cause those codes too .
  6. #5
    Aug 2007
    1,305
    Tweaking*
    The guy knows tansmissions, and i am not sure if this is due to the new converter installed, or if it is just a sensor that took a dump.
    I also had the dash that liked to shut down all the backlighting and the goofy driver number thingy. Some codes explain it.
  7. #6
    Aug 2007
    1,305
    [youtube]z2q--ggzmLA[/youtube]
  8. #7
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    i see a white box...
  9. #8
    Aug 2007
    1,305
    its a youtube vid of the codes
  10. #9
    68
    81,731
    Just the opposite. It DOES go off when it is 2 qts. low. It is a low oil level warning.
    I think the Transmission Range Switch is what we used to call the PRNDL switch.
    Quote Originally Posted by Crown Vic Owner View Post
  11. #10
    Oct 2005
    15,987
    post link of vids
    you didnt post it right
  12. #11
    Aug 2007
    1,305
    Quote Originally Posted by CadillacSTS2003 View Post
    post link of vids
    http://www.youtube.com/watch?v=z2q--ggzmLA
    my car is NOT low on oil,i know that. No messages on the DCC, and i checked it a bit ago.
    I pulled dipstick out, wiped, put back in, and rechecked at the same time, it was NOT low..
  13. #12
    Aug 2007
    1,305
    B1327 - Vehicle system voltage below 9.0 volts (history)
    B1328 - Vehicle system voltage is greater than 15.9 volts(history)
    B1328 - RH Sun Load Sensor Fault (history)
    B1652 - Loss of Keep Alive Memory (KAM) (history)
    B1983 - Device Power Circuit Low (history)
    B3033 - Security System Indicates Tamper
    B3055 - Key Not Present (i had to break into my car)
    P0603 - Control Module Long Term Memory Reset (history)
    P1599 - Engine Stall or Near Stall Detected (history)
    u1255 = Serial Malfunction (history)
    U1300 - Class 2 Short to Ground(history)
    U1064 - Loss of Communications with DIM(history)
    U1128 - Loss of Communications with IRC (history)
    Current
    U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) (current)
    C1738 - Exhaust Solenoid Valve Short to GND
  14. Remove Advertisements
