so when i went to pull codes, it just said all
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, so when i went to pull codes, it just said all in Cadillac Engine Discussion; it said all? i hit on off and it did nothing turned car off, did vise versa. Why did it ...
    Crown Vic Owner is offline Cadillac Owners Connoisseur
    Automobile(s): 98 sls
    Aug 2007
    1,305
    it said all?
    Why did it do this?
    There should be a code as the car wants to die when its at idle, i had the theft system tell me theft attempted today when i didnt use my clicker and alarm went off (i ordered a new clicker so it does not do that).
    69
    82,265
    Re: so when i went to pull codes, it just said all
    Check post #2 in the sticky in the Tech Tips section to be sure you are doing it correctly.
