Starting issue
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Starting issue in Cadillac Engine Discussion; I have a 99 seville SLS i have a problem starting the car i turn the key all the lights ...
    yatti's Avatar
    yatti is offline Cadillac Owners Member
    Automobile(s): Seville SLS
    Sep 2007
    Detroit
    14
    Starting issue
    I have a 99 seville SLS i have a problem starting the car i turn the key all the lights come on but it wont crank. I try this a few times and it will start i had a serv eng light and auto zone said it was th e EGR Valve i replaced that and still having trouble cranking. It almost sonds like a bad starter but i thoght i would hear some clicking. Can some point me it the right direction?
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Starting issue
    Quote Originally Posted by yatti View Post
    A bad ignition switch will do this and that is a known problem for 98 and 99
    Next a bad PK III module. Again it was new for the 98 and 99.
    I have replace several of both for a no start condition.
    yatti's Avatar
    Sep 2007
    Detroit
    14
    Re: Starting issue
    could a bad solenoid cause this issue
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Starting issue
    You should hear a click if it is the starter solenoid.
    The ignition switch problem is a power moding issue.
    yatti's Avatar
    Sep 2007
    Detroit
    14
    Re: Starting issue
    how hard is it to change the ignition switch
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: Starting issue
    YES.
    it pays about 2 hours.
    Ignition and Start Switch Replacement LHD
    Removal Procedure
    1. Apply the parking brake.
      Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
    2. Disconnect negative battery cable. This will maintain the key code.
      Caution: This vehicle is equipped with a Supplemental Inflatable Restraint (SIR) System. Failure to follow the correct procedure could cause the following conditions:
      • Air bag deployment
      • Personal injury
      • Unnecessary SIR system repairs
      In order to avoid the above conditions, observe the following guidelines:
      • Refer to SIR Component Views in order to determine if you are performing service on or near the SIR components or the SIR wiring.
      • If you are performing service on or near the SIR components or the SIR wiring, disable the SIR system. Refer to Disabling the SIR System.
    3. Disable the SIR system. Refer to Disabling the SIR System in SIR.
    4. Remove the radio or the navigation display module. Refer to one of the following procedures: Radio Replacement in Entertainment or Navigation Display Module Replacement .
    5. Remove the AC/heater control head. Refer to one of the following procedures: Control Assembly Replacement in HVAC System-Automatic.
    6. Remove the knee bolster. Refer to Knee Bolster Replacement .
    7. Remove the steering column. Refer to Steering Column Replacement in Steering Wheel and Column-- Tilt.
    8. Disconnect the electrical connectors from the ignition switch.
    9. Disconnect the park lock cable from the ignition switch. Refer to Park Lock Cable Replacement in Automatic Transaxle-4T80-E.
    10. Remove the ignition switch cylinder. Refer to Ignition Switch Lock Cylinder Replacement .
    11. Remove 1 fastener from the access hole in the IP at the steering column opening.
    12. Remove 2 fasteners from the radio opening hole. One fastener (2) is at the top of the opening and the other fastener is near the opening edge. The head of the screw is facing forward. This is a blind fastener. It can not be seen when installed.
    13. Rotate the switch in the IP.
    14. Remove the ignition switch through the radio opening.
    15. Remove the fasteners (1, 2, 3) securing the ignition switch bracket to the switch.
    16. Remove the ignition switch bracket from the ignition switch.
    Installation Procedure
    1. Install the ignition switch housing bracket to the switch.
    2. Install the fasteners (1, 2, 3).
    3. Install the ignition switch into the radio opening.
    4. Install the 2 fasteners to the radio opening hole, one fastener (2) is at the top of the opening and the other fastener is near the opening edge.
    5. Install 1 fastener to the access hole in IP at steering column opening.
    6. Install the ignition switch cylinder to the ignition switch housing. Refer to Ignition Switch Lock Cylinder Replacement .
    7. Install the park lock cable. Refer to Park Lock Cable Replacement in Automatic Transaxle-4T80-E.
    8. Connect the electrical connectors.
    9. Install the steering column. Refer to Steering Column Replacement in Steering Wheel and Column-- Tilt.
    10. Install the knee bolster. Refer to Knee Bolster Replacement .
    11. Install the AC/heater control head. Refer to one of the following procedures: Control Assembly Replacement in HVAC System-Automatic.
    12. Install the radio or the navigation display module. Refer to one of the following procedures: Radio Replacement in Entertainment or Navigation Display Module Replacement .
    13. Enable the SIR system. Refer to Enabling the SIR System in SIR.
    14. Connect the negative battery cable.
    15. Release the parking brake.
    yatti's Avatar
    Sep 2007
    Detroit
    14
    Re: Starting issue
    looks like a dealer issue huh
    TexasCadillac Guest
    Re: Starting issue
    Take all of the autozone parts off and replace with quality parts, autozone is known for bad electronics and low quality parts. good luck on your car. TexasCadillac
    68
    82,048
    Re: Starting issue
    Don't overlook the obvious. Battery and cables.
    yatti's Avatar
    Sep 2007
    Detroit
    14
    Re: Starting issue
    even though i get power could it still be the cables or battery when i let it sit iin the on position for a little while it will try to crank.
  13. Remove Advertisements
