SS Fuel Rail Removal
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, SS Fuel Rail Removal in Cadillac Engine Discussion; Help! The hood's up and wrenches out. I need to free the fuel rail to be able to remove the ...
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    69
    962
    I need to free the fuel rail to be able to remove the EGR. The 4 studs holding it down are free, can I simply pull the rail free of the injectors.
    Reason for this is the replacement rail was installed over the mounting bolt for the EGR, without a nut holding it down. To access the EGR bolt I need to move it, but with the other rail hold downs free (4 under the b'cover) the rail is still firm in place unless I can pop it free of the injectors to move it. K_C
    68
    81,883
    Re: SS Fuel Rail Removal
    I'd lift the injectors with it. Not sure, but I think that would be easier.
