Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know - Page 32
View Poll Results: Select one if you have had a problem with the headgasket the Northstar V8:
Voters
830. You may not vote on this poll
  • 1993
    20 2.41%
  • 1994
    39 4.70%
  • 1995
    13 1.57%
  • 1996
    43 5.18%
  • 1997
    159 19.16%
  • 1998
    180 21.69%
  • 1999
    185 22.29%
  • 2000
    90 10.84%
  • 2001
    65 7.83%
  • 2002
    54 6.51%
  • 2003
    15 1.81%
  • 2004
    8 0.96%
  • 2005
    6 0.72%
  • 2006
    2 0.24%
  • 2007
    1 0.12%
  • 2008
    0 0%
  • 2009
    0 0%
  • 2010
    0 0%
  • 2011
    0 0%
Multiple Choice Poll.
Page 32 of 35 FirstFirst ... 22 23 24 25 26 27 28 29 30 31 32 33 34 35 LastLast
Results 466 to 480 of 512
Like Tree21Likes
Northstar Engines and System Technical Discussion Discussion, Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know in Cadillac Engine Discussion; I have zero info on the cooling system history on this car, we were told that it was completely serviced ...
  1. #466
    Arrowhead is offline Cadillac Owners Member
    Automobile(s): None
    May 2013
    64
    6
    Re: Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know
    I have zero info on the cooling system history on this car, we were told that it was completely serviced and "ready to go" when we bought it in July of 2012 w/approx. 22,000mi.. As a precaution, I recently planned to do a coolant flush and right about that same time......the low coolant light started to appear. I read for hours about that engine's (4.6L LD8 N*) problems and various quirks. I wanted to believe that it was one of the many leak points like freeze plugs or crossover gaskets. I almost concluded that the dealer that sold us the car, when they did the coolant service, was unaware of the GM sealant tabs and maybe that was all that would be needed to correct a "nuisance" coolant loss. I was shocked when we bought a used 2000 Bonneville SLE in 2003 and I saw a dark, slimy mess in the coolant recovery tank. We were told then that it was from almond shells, etc. , completely normal and GM approved ! I guess it may be the age of the car (and coolant) that's caused the problem and that it's having less than 32,000 miles is not very relevant. It is a nice looking car that has a great exhaust note and is fun to drive, they're also relatively rare so, I guess we'll ultimately fix it and hang on to it. Might even acquire a spare engine as a back-up !
  2. #467
    mtflight's Avatar
    mtflight is offline Cadillac Owners Connoisseur
    Automobile(s): 1999 White Diamond ETC
    Jan 2005
    Dallas, TX
    2,538
    I don't think the GM Sealant tabs were used after 2003. I didn't have any in my 2003 DHS, no label. The original reason was to avoid nuisance leaks that could eventually result in low coolant. A car with a low coolant level is more likely to overheat and blow a head gasket. In this sense, it is plausible that they can [indirectly] help prevent a blown HG. I had a crossover coolant leak, and it went away with the tabs. They are indeed made from crushed ginger root and walnut shells--they find leaks and expand when dry, effectively plugging small leaks. The dark mess in the 2000 Bonnie was probably overuse of these tabs, or they were put in the low flow reservoir instead of in a high flow coolant area, such as the radiator hoses. It's definitely a nice car and very worth the repair in my opinion. Do the repair well with someone who has experience or do it yourself to be sure it's done right (not for the faint of heart lol). Various members here have done it themselves. Maeng9981 did two!
  3. #468
    Automobile(s): None
    May 2013
    64
    6
    Well, we'll see what the service agreement issuer say's, hopefully it'll all be covered at the Cadillac dealers shop. If not........I've already got a drill, torque wrench and an average strength heart! (for a 60 year old )
  5. #469
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 Honda Accord EX V6. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    27
    3,718
    Have been looking at a few N* Cadillac's again to replace my BMW. I found a *gorgeous* '98 Deville for $4400 with 85k miles and really the only thing that holds me back on these cars is the HGs. If it were to fail I would try to fix it myself with the help of a few friends or take it down to Rippy. It seems that the HG jobs on these cars is getting cheaper and cheaper to do.
  6. #470
    gord is offline Cadillac Owners Member
    Oct 2005
    1
    I had seen elsewhere in this thread that the 200? engines are bulletproof. My 2005 started misfiring a little on start-up a week ago, so I decided to pull the spark plugs and yup, there's coolant in cylinder #8. So I added my tick to the 2005 year. Interesting that I'm following not far behind Arrowhead, the other 2005 entry.
    Is there any other reason that this could be there besides a head gasket failure? (My old '94 had a water passage gasket that cracked that allowed water into the EGR passage which found its way into the intake but I don't see anything like that in the FSM drawings. Could always be a cracked head or block, but I really hope we aren't going there!)
    Since my motor already has the coarse threads, from what I've read throughout these HG threads, my motor shouldn't be pulling the bolts from the block. I would imagine head gaskets do fail so could it be nothing more than that? Chris posted in #456 that, since mine has the coarse threads, all that's needed to do is replace the gaskets and put the motor back together with the usual due diligence. Did I paraphrase you correctly Chris? Should I be expecting to stud my engine?
    Thanks all for the great reads in the forum!
    Gord
  7. #471
    68
    81,926
    Quote Originally Posted by gord View Post
    No such thing. If it's got HG's, there is always the possibility of a failure. That said, the 2000+ engine are less prone to failure than the pre-2000's.
  8. #472
    the recluse is offline Cadillac Owners Connoisseur
    Automobile(s): 2002 STS, 1991 Eldorado
    Feb 2009
    Jacksonville, FL
    1,023
    2002 STS with 175,000 miles...after pulling the plugs (the night the HG totally went) I see coolant on the plugs...prolly been burning coolant for the last 5-6K miles...
  9. #473
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the switch to coarse threadpitch in 2004 (there's a thread to tell if your 2004 has coarse threads or not) solved the "head bolt pulling out of the block" issue but did not make them bulletproof
    just for the record, my '99 had failed gaskets (the bolts were not pulling out of the block)
  10. #474
    Feb 2009
    Jacksonville, FL
    1,023
    Agreed...the gasket itself can collapse and virtually "implode"
  11. #475
    starbond's Avatar
    starbond is offline Cadillac Owners Member
    Automobile(s): 1998 Deville Base
    Jul 2010
    Columbus, Ohio
    26
    88
    1998 Deville - Coolant issues around 92k miles. HG failure around 94k
    Car wasn't overheating but coolant keep disappearing every other week. Did a block test recently and it turned yellow. It's a shame really. Not even 100k and the car is already on its way out..
  12. #476
    wingman64 is offline Cadillac Owners Member
    Automobile(s): 2000 DeVille
    Nov 2011
    S.F/Bay Area
    21
    Re: Cracked engine block on 2000 Cadillacs
    Add one more 2000 DeVille to the list. Cady dealer here just gave me the bad news. This vehicle has had every ounce of care one could possibly give over these past 13 years. Too much to list. Engine crankcase seals, head gasket mod and a lot more. Regular Cadillac service all along. 120,000 miles. P0741 by itself for the last 1.5 years and 20,000 miles with only a few mpg loss to show for it. Super clean car.
    Oh well. It was my dad's car and was given me upon his death 3 years ago. Not sure what to do with it? Any suggestions?
    Moderator EDIT: wingman64, You need to enter your car data in the poll - only the originating member can update the averages.
  13. #477
    knotgoalie's Avatar
    knotgoalie is offline Cadillac Owners Fanatic
    Automobile(s): 04 DHS
    Oct 2013
    Ontario, Canada
    60
    279
    Wow, 32 pages in and so far not a single report for 04. I sure can't complain about that.
    J.R.
  14. #478
    jball is offline Cadillac Owners Member
    Automobile(s): CTS, DeVille
    Nov 2010
    52
    3
    Re: Definitive Northstar Headgasket Thread
    98 SLS 80,000 miles internal headgasket leakage causing overheat.
    Coolant pushed out of jug, temp gauge would climb underload.
    No threads pulled out of block.
    Replaced gaskets, headbolts and waterpump.
    Runs fine now.
  15. #479
    gino9's Avatar
    gino9 is offline Cadillac Owners Fanatic
    Automobile(s): Eldorado 4.5 88' & STS 4.6 N* 01'
    Sep 2009
    Oxford,UK
    34
    165
    2001 seville sts
  16. #480
    Nov 2011
    S.F/Bay Area
    21
    Hey Guys,
    Add my 2000 DeVille to the Cracked Engine Block list. Confirmed today after removing the passenger side engine to trans axle support bracket. Cracked at # 3 cylinder area. Bye-Bye my beloved DeVille. At least its going to a great home, my brother in law is a GM mechanic. He's going to swap the engine/trans (P0741) and this immaculate vehicle will once again grace the road. All the very best to you all. Signing off ......
  17. Remove Advertisements
