Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know - Page 30
View Poll Results: Select one if you have had a problem with the headgasket the Northstar V8:
Voters
830. You may not vote on this poll
  • 1993
    20 2.41%
  • 1994
    39 4.70%
  • 1995
    13 1.57%
  • 1996
    43 5.18%
  • 1997
    159 19.16%
  • 1998
    180 21.69%
  • 1999
    185 22.29%
  • 2000
    90 10.84%
  • 2001
    65 7.83%
  • 2002
    54 6.51%
  • 2003
    15 1.81%
  • 2004
    8 0.96%
  • 2005
    6 0.72%
  • 2006
    2 0.24%
  • 2007
    1 0.12%
  • 2008
    0 0%
  • 2009
    0 0%
  • 2010
    0 0%
  • 2011
    0 0%
Multiple Choice Poll.
Page 30 of 35 FirstFirst ... 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 LastLast
Results 436 to 450 of 512
Like Tree21Likes
Northstar Engines and System Technical Discussion Discussion, Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know in Cadillac Engine Discussion; Joe, have you been tapping the block on these coarser threaded head bolt engines? it is my understanding that all ...
  1. #436
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know
    it is my understanding that all the failures in engines with the coarser threaded head bolts were due to the bolts not being tight to begin with and not from pulling out
    that then causes the gasket to fail compounding the issue
  2. #437
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,915
    From a mechanical standpoint I like fine threads on studs/head bolts. It allows for more precise torque application as opposed to an initial torque then degree sequence.
    Coarse threads in aluminum are just fine for the "meat" of an insert or stud grab - then sneak up on proper torque with well-rolled fine threads on the stud/nut or the original fine threads on a head bolt into a large insert. Look at the threads in Norm's Inserts. Coarse outside, fine inside.
  3. #438
    Sep 2007
    Wilmington, NC
    13,986
    yeah, that's the same as the bigsert approach
  5. #439
    JoeTahoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 GMC SLT, Malibu LTZ, 99 STS studded with NP
    Jul 2010
    Central, NY
    48
    502
    Chris when did the coarse threads start as I haven't had any thing newer than a 02 myself. Tomorrow a 04 deville is being delivered to me and I just gave my knowledge on a 05 but I did not see it. But they studded it with jakes studs
  6. #440
    Sep 2007
    Wilmington, NC
    13,986
    some 2004 ... but all 2005
    see this thread for the nitty gritty details
    http://www.cadillacforums.com/forums...ead-pitch.html
  7. #441
    Jul 2010
    Central, NY
    48
    502
    thanks for the link that is a must have, Takes a lot of guess work out
  8. #442
    Sep 2007
    Wilmington, NC
    13,986
    Yeah... that's definitely one of the little golden nuggets that you often find around these parts
  9. #443
    Jul 2010
    Central, NY
    48
    502
    This forum is the bible for all caddy owners
  10. #444
    Feb 2006
    55,915
    Re: Definitive Northstar Headgasket Thread
    But only 8 people in the world know that - the rest never search for the answers to every Cadillac problem: They're already posted in the stickies in each forum threads header and in Discussions, Cadillac Tech Tips.
  11. #445
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    Quote Originally Posted by Submariner409 View Post
    SO, Jim, WHO are those 8?
    Kidding, kidding
  12. #446
    Jul 2010
    Central, NY
    48
    502
    Ok this is the second one I have had apart in the last two weeks. It appears to me that the head gaskets failed no aluminum pulled when removing the bolts 1st one was a 02 DTS with fine threads 2nd one is a 04 Deville with coarse threads, both failed #1 cylinder I will post pics once I go in
    fine tread vs coarse
  13. #447
    Jul 2010
    Wyoming
    26
    5,740
    Well, these are aluminum engines. They run the risk of HGs, it's just WAY less with coarser threads.
  14. #448
    Jul 2010
    Central, NY
    48
    502
    One would figure that a car with less than 100, 000 miles and under 10yrs of age woud not have this problem. Again this is just my thoughts
  15. #449
    Feb 2006
    55,915
    Hmmmmm................ Your latest set of pictures makes a powerful argument for the "Either/or: Gasket/bolt" failure.
    That IS one pathetic looking head gasket.
  16. #450
    Jul 2010
    Central, NY
    48
    502
    Sub the last 2 were definitely headgasket failures not thread failures
  17. Remove Advertisements
