Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know - Page 19
View Poll Results: Select one if you have had a problem with the headgasket the Northstar V8:
Voters
830. You may not vote on this poll
  • 1993
    20 2.41%
  • 1994
    39 4.70%
  • 1995
    13 1.57%
  • 1996
    43 5.18%
  • 1997
    159 19.16%
  • 1998
    180 21.69%
  • 1999
    185 22.29%
  • 2000
    90 10.84%
  • 2001
    65 7.83%
  • 2002
    54 6.51%
  • 2003
    15 1.81%
  • 2004
    8 0.96%
  • 2005
    6 0.72%
  • 2006
    2 0.24%
  • 2007
    1 0.12%
  • 2008
    0 0%
  • 2009
    0 0%
  • 2010
    0 0%
  • 2011
    0 0%
Multiple Choice Poll.
Page 19 of 35 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... LastLast
Results 271 to 285 of 512
Like Tree21Likes
Northstar Engines and System Technical Discussion Discussion, Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know in Cadillac Engine Discussion; '98 Deville with 107k- HG were blown before I purchased car but I was not told that but I found ...
  1. #271
    Big Pip's Avatar
    Big Pip is offline Cadillac Owners Fanatic
    Automobile(s): '72 Coupe DeVille
    May 2008
    Central FL
    104
    re: Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know
    HG were blown before I purchased car but I was not told that but I found out 3 days later!
    Dealer is dropping motor and installing a Stud Kit. They were originally going to just replace the HG's with the motor in the car but then he realized that this car was a '98 and not a '93 (I have no idea where he got the impression it was a '93) and notified me that the repair on this car is to instal the Stud Kit which requires dropping the engine. I am not going to argue because 1st) I wanted the stud kit installed anyways and 2nd) I sure as hell wouldn't want to drill into the rear side of the motor with the firewall right there!
    I was told they would be done on Monday 10/26. God I hope so, I haven't even driven this car 100 miles yet!
  2. #272
    mangotel is offline Cadillac Owners Member
    Jul 2004
    16
    1997 ElDordo - 235k miles
    I've been told it isn't fixable. The headbolts will pull out if torqued back to spec during the headgasket repair attempt.
    Is this true?
    Is Cadillac saying anything about this?
    What options do you recommend?
    mangotel
  3. #273
    00 Deville's Avatar
    00 Deville is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Deville / 04 Deville
    Mar 2004
    Wilmington, NC
    52
    2,659
    Quote Originally Posted by mangotel View Post
    Is this true?
    mangotel
    It is fixable... you have to repair all 20 holes in the block with either...
    Studs http://Northstarperformance.com
    Norm's Inserts
    Timeserts
    I would recommend either the Studs or Norms Inserts... Timeserts are not as strong of a repair. Expect to pay $2000-$2500... most dealers will charge $3500-$4500 and use Timeserts. If you have any more questions I would recommend starting a new thread in the N* section of the board.
  5. #274
    AlBundy's Avatar
    AlBundy is offline Cadillac Owners Master
    Automobile(s): 1996 Eldorado Sport Coupe, 2009 Black Navigator
    Jul 2005
    Chicago
    41
    5,016
    I see 97, 98, 99 are still increasing since I last visited this thread.
  6. #275
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    My 95 Eldo is still all original, runs great.
  7. #276
    68Futura is offline Cadillac Owners Member
    Automobile(s): 1998 Seville SLS
    Dec 2008
    29
    17
    My 98 sls made it just over 107k miles. Although I haven't had the coolant tested yet, the temp gauge is bobbing up and down. a sure sign from what I here, but i'll look into it more before I jump to conclusions... Looking at a wrecked 03 sls w/80k to fix up with parts from my 98. I see from the pole that the engines got better after 2000, but that could partially be just cuz they haven't had as much time to fail yet. Anyone else think this may be the case? or did GM in fact greatly improve these engines?
  8. #277
    AlBundy's Avatar
    Jul 2005
    Chicago
    41
    5,016
    Quote Originally Posted by clarkz71 View Post
    Ditto clarkz. How it going? I've been gone for awhile but it's still good to hear from you guys. My transmission sensor is almost gone but the Eldo is still going.
  9. #278
    whitesls is offline Cadillac Owners Member
    Automobile(s): 1997 Seville SLS
    Nov 2009
    4
    My 1997 Seville SLS had the head gasket/pulled bolts problem around 50k miles. The dealer replaced the gasket and "repaired" the pulled bolts which lasted about 8 months before it went bad again. Then one final try at an independent mechanic shop and lasted about 1 month.
    It now sits parked in the garage....a beautiful piece of art to admire. It still starts with a perfect body and everything functions...except the engine blows smoke so it is not drivable on the road. Sad sad sad.....See this link for a video of car as I pulled it outside for pictures: [ame="http://www.youtube.com/watch?v=UlvNjqVtSj4"]YouTube- 1997 Cadillac SLS[/ame]
  10. #279
    Nov 2009
    4
    Has anyone heard about the quality of engines at northstarperformance.com?
    I am in northern california and am tempted to use their rebuilt engine (reasonable price at $2600) and find a quality experience northstar engine installer in my area to install the engine.
    Any thoughts are welcome. Thank you.
  11. #280
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Quote Originally Posted by whitesls View Post
    Everything would indicate that Jake is a real stand-up guy - there is no one more reliable that I know of.
  12. #281
    olsonscottm is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Jan 2009
    Palmer, Alaska
    76
    1998 Deville, 130,800 miles. Repaired September 2009 in my garage for $800.00 (stud kit, various gaskets, battery, coolant, etc) now have 137,500 miles on it and not a lick of trouble.
    Scott
    Palmer, AK
  13. #282
    Nov 2009
    4
    Thanks for the replies! I am in the process of ordeing the engine and look forward to having it installed soon. Cheers!
  14. #283
    Mark Shulaw is offline Cadillac Owners Member
    Automobile(s): Deville
    Dec 2009
    Unhappyre: Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know
    Hello, I am a tenderfoot with a Cadillac. I finally got my first one this August. Always have wanted a Caddy and finally was able to go with a nice clean second owner granny driven (I know the last owner and she really is a granny) 1997 DeVille w/Northstar. LOVE the car, but Now I am wishing I had done more homework before buying. She did not have any trouble with it but only drove it around town and the area and the local mechanic took care of it once a month for her and only occasionally added a bit of fluid in the last year. I found this site while looking for some hope for the engine. Every one is telling me to junk it don't dump good money after bad. It had 69,000 then and now it has 75,000 and its been steadily using more and more DexCool and overheating. Went through the usual checks, no cloud out the tail pipes no coolant in the oil. Changed rad, pump and thermostat. Temps run some better but still overheats and looses coolant. Last week I caught it dumping it out the overflow tube. finally checked for gasses in the cooling system and got a posititive for carbon monoxide. Should I dump a minimum of another $2000. in this car or cut my losses and run from my nightmare. Guess theres no real way to tell till the engines down to see if its a gasket, bolts, head or block?. From what I see here these engines can be a night mare. Dissapointed first time Caddy owner. Mark
  15. #284
    Jan 2009
    Palmer, Alaska
    76
    Mark,
    I have a '98 Deville and abolutely love the car! Well worth the $800.00 in parts and my labor to fix the head gaskets.
    If you don't want to (or can't) fix the head gasket yourself, I'm not sure it's economically worth it to keep it. I like to tinker with things anyway, so while it was an inconvenience, I enjoyed pulling the engine, taking the heads off, drilling and tapping the block etc.
    Then again, I bought mine suspecting bad head gaskets (hoping for the best, however) for real cheap, so I'm into my Caddy for less than $4K, all repaired.
    The only other problem I've had is the turn signal self cancel spring broke and I had to take the steering wheel off to replace it. I highly recommend getting a copy of the Factory Service Manual (FSM) to help with things.
    I get to drive my Caddy about 100 miles a day for my commute, and it just doesn't get better than this (alright, heated seats would be nice). I get upper 20's for mileage door to door, and just north of 30 on the highway.
    Feel free to post more questions etc. I think if you do fix it, you'll be very happy.
    Scott
    1998 Deville
    Palmer, AK
  16. #285
    bross765 is offline Cadillac Owners Member
    Sep 2009
    Mines a 98, perfect in every other way. Don't know if its worth fixing. It makes me sick.
  17. Remove Advertisements
