GM now offers Premium Remanufactured 4.6L Northstar
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 65
Northstar Engines and System Technical Discussion Discussion, GM now offers Premium Remanufactured 4.6L Northstar in Cadillac Engine Discussion; DESCRIPTION: Effective November 9, GM Parts will provide a remanufactured 4.6L Northstar Premium V8 Engine (RPO-L37/LD8). This engine will provide ...
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    TalkingGM now offers Premium Remanufactured 4.6L Northstar
    DESCRIPTION:
    Effective November 9, GM Parts will provide a remanufactured 4.6L Northstar Premium V8 Engine (RPO-L37/LD8). This engine will provide an viable alternative to repowering your customer's late-model Cadillacs. Available on Powertrain Wholesale Truckload Program.
    EFFECTIVE DATE:
    Available November 9, 2007
    ORDER INPUT:
    Order via RAPID.
    GENERAL INFORMATION:
    Each reman Northstar engine includes all of these brand new components:
    Cylinder Block
    Crankshaft
    Pistons and Piston Rings
    Crankshaft Bearings
    Camshafts
    Oil Pump Assembly
    Intake and Exhaust Valves
    Timing Chain
    All Gaskets and Seals
    Also, for customers desiring to rebuild their own Northstar engines, GM Parts offers two short block assemblies.
    These short block assemblies include all new:
    cylinder block castings
    pistons, connecting rods
    crankshaft and bearings
    Applications:
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,881
    Re: GM now offers Premium Remanufactured 4.6L Northstar
    AJ, You have just made some '90's owners into Happy Campers. Betcha this Forum had a little something to do with the decision.
    Now, where can I get a GM long block for '02 STS L37 ???
    Lord Cadillac is offline Cadillac Maniac
    Automobile(s): Cadillac Escalade
    Dec 2002
    Royal Palm Beach, Florida
    45
    13,684
    How much will these engines cost? Any idea?
    Have an iPhone or Android? Then you can be connected with everything automotive in your area.
    Download the Cars Connected app for your iPhone or Android device today! Or you can check out Cadillac Magazine...
    857,000,000 Car Photos - take a look!
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Yeah that's going to be a score for a lot of people.
    Gearheaad43's Avatar
    Gearheaad43 is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 Polo Green Cadillac Seville STS
    Nov 2006
    Georgia
    685
    Ummm Do they include timeserts? Higher tension oil rings? better seals?
    Are these avail thru GM Parts Direct?
    How much do they run AJ?
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Timesert suck!
    Higher tension rings suck!!
    They will be getting prices soon.
    Nov 2006
    Georgia
    685
    Well, ok Timeserts sucks.. I meant Bigserts.... :-P
    Why does higher tension rings suck? They serve to lower oil consumption which we all know the Northstars are famous for.....
    The only negative I can think of with higher tension rings are increased wear on the cylinder liners... I'd rather have a little wear in 300,000 miles than having to constantly wonder how much oil my N* is drinking up........
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    I believe the oil consumption is there for a reason.
    And why do Timeserts suck?
    68
    81,916
    I'd rather have the oil consumption and less ware. I can add oil, can't add ring or cylinder ware. When that happens you're gonna use oil anyway. An added benefit to oil consumption is that you are occasionally fortifying the oil additives between oil changes.
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Is there a "low oil" warning feature on the N* engine,or should you check dip stick from time to time?
    68
    81,916
    Yes, there is a level sensor and you will get a CHECK OIL LEVEL message when it is 2 qts low, just about the time it drops off the end of the dipstick. It will warn you before it lets you hurt it.
    Nov 2005
    3,013
    Thank you again.
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by Gearheaad43 View Post
    I completed an online ring course a while back. I think they said 80% of the engines drag comes from rings. The new style rings work without problems in most engines.
    Example:
    4 cylinder car get on the freeway uses 70%+ throttle.
    6 cylinder car or van will see less, maybe 50%+.
    Now the Northstar. The older people don't like the noise, the slightly younger group don't have the time and are worried about abuse (you could not do this to a car in the 80's). The next group below that in my opinion likes to do it, but the time thing again.
    You must force Combustion chamber pressure behind the ring to force them out against the cylinder wall. This also forces carbon bind the rings. Good clean oil and WOT will cut down on oil consumption.
    Quote Originally Posted by codewize View Post
    TimeSerts are not part of the block they just make the bolt bigger!
    They is truly what they do. So if you have a NEW casting why would you want to ruin it with TimeSerts. TimeSerts are a Bandaids.
    I am with you on this.
  16. #14
    Feb 2006
    55,881
    Gearhead43, I believe GM will be using all new blocks due to the cast-in liners. Timeserts or equivalent wouldn't allow GM to issue much of a warranty.
    Low-tension rings do not, by design, make a N* or any other engine an "oil burner", and N*'s aren't famous for oil burning. A few in here are, and the forum is concentrated, so it appears that the percentage is much higher than actual. (How many N* cars do you see on the highway, leaving a plume of oil smoke ???) The official GM stand on oil consumption is now 1 qt./2,000 miles, up from 1 qt./1,000 miles a year ago. There's a thread in here somewhere, recently, about just that.
    (We use low tension compression rings and 3-piece oil control rings in our custom boat engines, and an Olds 455 generally turns 2,600 to 3,400 rpm all day, while a GM 454 turns up to 4,350 all day, both with negligible oil consumption.)
  17. #15
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    So am I to understand these new reman motors are supposed to be a better alternative to timeserting your current motor? And are they supposed to not suffer the same failure in the future?
    And again, WHAT'S THE COST?
  18. Remove Advertisements
