After head gasket repair engine knocks
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, After head gasket repair engine knocks in Cadillac Engine Discussion; This is my first N* and i was really happy up to now. I just finish replacing the head gaskets ...
    CadyPR is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2007
    This is my first N* and i was really happy up to now. I just finish replacing the head gaskets on my N* 1997. My mechanic misplace the "Knock Sensor that gose to the lower back side of the engine block (Engine blcok to firewall) and still we have not replace it. But anyway we started the engine and it has an engine knock when we rev it up, as soon as the engine RPM's stabilized (maintain the engine at a custant RPM) it goes away. This repair took my mechanic almost 3 weeks to complete, could it be that the rings sticks and make the piston snap against the cylinder walls???? Or it could be because it is missing the sensor?????
    Scotty7751's Avatar
    Scotty7751 is offline Cadillac Owners Fanatic
    Automobile(s): 04 Cadillac CTSV
    Aug 2007
    Dallas, Tx
    29
    380
    Re: After head gasket repair engine knocks
    doesnt the knock sensor adjust timing based on what it hears? so i think it would be the sensor. and piston slat happens with he skirt of the piston so if you have like really short skirts on a piston it will knock bad when its cold cus the skirt hast heated and swollen up. that is what happens with the 6.0 truck motor if you listen the 6.0 it knocks on first startup.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Could be the sensor. What kind of gas are you using?
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    moved.
    questions belong in the proper forum for your vehicle.
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Quote Originally Posted by CadyPR View Post
    I have seen it many times.
    Bad cams!
    I will post a picture later
    Nov 2007
    I think I got it, apparently it was that ignition cable #2 & #4 arcing, apparently this was causing to ignite cylinder #2 when it was coming up to its compression cycle and causing the piston to knock. Today i will go and buy new cables, i will advise tomorrow.
    Life is Good!!!!
  9. Remove Advertisements
