96 Cylinder head on 93 block
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 96 Cylinder head on 93 block in Cadillac Engine Discussion; Hi, newcomer here, just like to know if 96 cylinder head would fit on a 93 block, the engine goes ...
    proyan is offline Cadillac Owners Member
    Automobile(s): Cadillac Seville STS 1993
    Sep 2007
    Montreal
    37
    3
    Hi, newcomer here, just like to know if 96 cylinder head would fit on a 93 block, the engine goes in a 93 STS, the HG is blown and i could get the 96 heads, witch are completely redone, for cheap
    thanks
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    Re: 96 Cylinder head on 93 block
    Quote Originally Posted by proyan View Post
    thanks
    Yes they will bolt on. No they will not work for your application. The heads are not the same.
    68
    81,917
    Why do you think you need to replace the heads? It is the gasket that went bad. Be sure to Timesert the block unless you want to do it again.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    The heads don't go bad very often. Your's are probably good.
  7. Remove Advertisements
