My car has 121k on it..should I change the trany fluid?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, My car has 121k on it..should I change the trany fluid? in Cadillac Engine Discussion; I would like to change it, she runs good now. Fluid looks good. Im not quite sure if it was ...
    limoguy is offline Cadillac Owners Fanatic
    Automobile(s): 98 Deville Delegence
    Oct 2007
    Long Island, NY
    198
    I would like to change it, she runs good now. Fluid looks good. Im not quite sure if it was ever changed. I doubt it though. What do you think I should do, I dont want to open up a can of worms either. How many filters are in there? Should I change them all? Thanks
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    Re: My car has 121k on it..should I change the trany fluid?
    In a word,.... yes. Use dexron VI fluid. I know you can get it through a dealer
    or online. I don't know if any of the other oil companys sell it yet.
    There are two screens once you remove the pan that can be cleaned.
    There's a drain plug near some wiring near the pan rail that drains the side pan. I belive
    it's a 11mm.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,836
    Sure. Change what you can get out (some will remain unless you do a total overhaul) and switch to DEXRON VI. The latest TSB states that it is compatible with previous fluids.
    Don't forget that these are semi-dry sump transmissions, so you will not see any fluid on the dipstick with the engine off. You must check the fluid according to the manual. Measure and replace only what drained.
    I did mine 6 weeks ago and am pleased with the overall "feel" of the transmission during normal and looney driving.
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    Quote Originally Posted by submariner409 View Post
    Do you know how much of the fluid actually came out?,my 97 sts shows a capacity of 15 qts.
    68
    81,883
    I think I got 12 or 13 qts. out of my '97 without pumping the torque converter.
    Nov 2005
    3,013
    [quote=Ranger;1276452]I think I got 12 or 13 qts. out of my '97 without pumping the torque converter.[/quo
    Thanks again, just wanted to know how much I had to buy.
    Oct 2007
    Long Island, NY
    198
    Thanks for the info everyone. I will get this done soon.
  10. Remove Advertisements
