Friends Used 1999 DeVille
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Friends Used 1999 DeVille in Cadillac Engine Discussion; I have a friend of mine that just got a used 1999 deville. I pulled the following codes off of ...
    Roswell256's Avatar
    Roswell256 is offline Cadillac Owners Fanatic
    Feb 2004
    Quantico, VA
    35
    285
    I have a friend of mine that just got a used 1999 deville. I pulled the following codes off of his computer. The vehicle wasn't running so I don't know if any are current. I'm going to clear and see if any come back.
    P0463 Fuel Level Sensor Circuit High Voltage
    P0603 Control Module Long Term Memory Reset
    P0741 TCC System Stuck Off
    P1520 Transmission Range Switch Circuit
    P1527 Transmission Range to Pressure Switch Correlation
    P1599 Engine Stall or Near Stall Detected
    P1602 Loss of EBTCM Serial Data
    P1604 Loss of IPC Serial Data
    P1605 Loss of HVAC Serial Data
    B1341 Air Mix Door Two Movement Fault
    Does anyone know if any of these codes...or a combination of them may point to the vehicle ever having a serious problem? My friend says he has a feeling that it may have been in a wreck then fixed, but he's not for certain. I'll post finding after I clear it. If any come back I'll let you know. I'll keep searching the forum for mor info, but if anyone has an idea I'd appreciate it.
    Thanks
    -Roswell-
    OlManRivah's Avatar
    OlManRivah is offline Cadillac Owners Fanatic
    Mar 2004
    Central Virginia
    112
    Re: Friends Used 1999 DeVille
    Have him try to pull the history from Carfax.
    Get the car running.
    Clear the codes.
    And, see what, if any, codes develop.
    Save those codes, you pulled, for future analysis.
