Is there an easy way to change coolant?
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Northstar Engines and System Technical Discussion Discussion, Is there an easy way to change coolant? in Cadillac Engine Discussion; what would you sugjest is the easiest way to do it? remove lower hose & let drain? drain radiater? does ...
    limoguy is offline Cadillac Owners Fanatic
    Automobile(s): 98 Deville Delegence
    Oct 2007
    Long Island, NY
    198
    drain radiater?
    does it really matter what brand of coolant is used?
    dont they all do the same?
    thank you
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,393
    Re: Is there an easy way to change coolant?
    Easiest way ? I think unplugging the drain plug lol
    Oct 2007
    Long Island, NY
    198
    drainplug on the radiater?
    will that drain it all out?
    Dec 2003
    36
    4,393
    It should be somewhere under the rad . Still, it might not drain it all out and this is when you can need flushing the cooling system
    Sep 2003
    Metro ATL
    4,854
    Drain as much as possible and refill with GM approved (licensed) Dex-Cool mixed at 50/50 with distilled water. Approved vendors are permitted to say Dex-Cool on the container; Havoline and Prestone are two such vendors.
    Pulling the inlet and outlet hoses will drain about 4 quarts. Some models have a drain valve at the left side of the radiator. Using a little air pressure will force a little more out.
    Catch the old coolant in a container as much as possible. The corrosion inhibitor package is acid based and potentially painfully fatal to small animals. Then there is the contamination of the ground water system if you let the old stuff hit the ground and go wherever gravity takes it.
    I would not use any "flush" technique on my cooling system. Using a "flush" product from the aftermarket introduces who-knows-what chemicals into the system. Not for me. And, water flushing is guaranteed to lose control of the desired 50/50 mix ratio.
    Back to the top; drain as much as possible and refill.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    Here we go again.
    There is no lower hose. it's in the middle of the tank. DO NOT FLUSH
    There's a drain plug on the bottom of the radiator. Pull that and you'll get about half the total coolant out. That's all you need.
    Put 4 GM seal tabs in the upper hose. Refill with a 50/50 mix of Dex and Distilled water.
    This is NOT by any means a difficult or long procedure.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
    69
    82,269
    The radiator has a drain plug for a reason. It is the lowest point in the system. Drain it there to get the maximum amount of coolant out.
    Oct 2007
    Long Island, NY
    198
    thanks everyone..I apreciate the help
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    this was like just covered two days ago lol
    Oct 2007
    Long Island, NY
    198
    thats why theres erases on pencils, cadillac. maybe you are perfect, i guess
    Oct 2007
    Long Island, NY
    198
    cant find the drain plug!!
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,284
    Take it to the dealer.
    Don't mess with Binky Bear!
    Oct 2007
    Long Island, NY
    198
    thats the last resort..ill ask someone at the auto parts store first..i alreay have all the stuff to do it
  16. #14
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,284
    Do some searches on the forum before you give up. This subject has to have been covered a hundred times.
  17. #15
    69
    82,269
    There should be a hole in the splash shield right below it. Get a 3/4" dowel rod and cut a slot in the end of it. Use that as a key to turn the plug. The other alternative is to pull the splash shield. That should be relatively easy. Once you see where it is and how to open it, the next time will be a cinch.
  18. Remove Advertisements
