what is considered normal coolant temperture for a north*?
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Northstar Engines and System Technical Discussion Discussion, what is considered normal coolant temperture for a north*? in Cadillac Engine Discussion; My 98 deville with 120k, runs from 196 on the highway & between 196-223 without the A/C on in traffic. ...
    limoguy is offline Cadillac Owners Fanatic
    Automobile(s): 98 Deville Delegence
    Oct 2007
    Long Island, NY
    198
    My 98 deville with 120k, runs from 196 on the highway & between 196-223 without the A/C on in traffic. Is this normal?
    Sep 2003
    Metro ATL
    4,854
    Re: what is considered normal coolant temperture for a north*?
    Based on my driving experience (approx. 190,000 miles on two different cars), my answer would be YES. You are seeing normal and expected temperatures under the conditions you mentioned.
    69
    82,265
    My '97 Deville was the only digidash I had. I ran 205 (summer) to 215 (winter). Your temps still sound about normal. Cooling fans don't come on till 224.
    Oct 2007
    Long Island, NY
    198
    thanks guys
    LCLCLC is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville
    Mar 2004
    244
    Your car is running correctly.
    Cadillacs are strange. Basically, they run cooler with the AC running.
    With the AC running, the fan is turned on. With the fan on, it will maintain a 197degree theromostat level.
    If you have it in 'Econ', this means the AC will not run. With the AC not running the fans are not on. Until the temp hits about 220degrees, then the fans turn on.
    Therefore, a Cadillac will run cooler with the AC on.
    Oct 2007
    Long Island, NY
    198
    My fans dont seem like there running fast enough when a/c is on. Is this possible? I was driving with the hood in the partly open position to get more air in. Hot day, so i had A/C on, usually the coolant temp stays around 200. I saw it go up to 217. That cant be good, can it?
    69
    82,265
    205-215 is normal operating temperature. Nothing to get worried about.
    Oct 2007
    Long Island, NY
    198
    thanks ranger...Im better off not looking at the temperture gauge. I will change it to RPM mode!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,821
    limoguy......I just did another post on thermostats......your engine is set up so the thermostat begins to open at 188 and is fully open at 206. The engine is designed to run at 210 or so, all the time. The 18# pressure cap lets the coolant go to 264 before boilover. The fan(s), in normal engine cooling mode, come on at 222-224, slow, and go to fast at 236. One fan or two runs in slow when the HVAC system is set to use the a/c compressor for some function, whether cooling or defrosting. Fan(s) generally will not run at all above about 40-45 mph due to airflow through the engine compartment.
    FWIW, the fans also go to fast at a transmission temp of 302. 302.
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    69
    962
    Quote Originally Posted by submariner409 View Post
    Thanks for the fan speed info. I recently took a look at the fans and noticed it didn't look like it was up to speed, now I understand why. K_C
    Feb 2006
    56,821
    Yeah......a fan in slow really looks like it is just loafing along. Not sure about your year's setup, but my '02 uses a set of fuses and relays, in the engine room box, to run the fan(s) in slow with a series hookup or in fast, parallel hookup. If you pull the relays, the contact diagram is on the bottom and you can figure out the various speed/hookup configurations.
    One fan jumpered to high across the relay socket with a piece of 18 gauge copper wire will smoke the wire and the tips of your fingers. Ask me how I know........When a fan's in high, it roars !!
    Oct 2007
    Long Island, NY
    198
    What a jackass I am. The car was short 2 quarts of oil, made it run those higher coolant temps. I added the oil & she runs at 197 degrees with A/C on. Sorry for the confusion. Very happy it was a no brainer!!
    69
    82,265
    2 qts low will have absolutely no effect on the engine temps.
  16. #14
    Feb 2006
    56,821
    ............matter of fact, the "check oil" light doesn't come on until somewhere around 2 quarts low.
  17. #15
    Oct 2007
    Long Island, NY
    198
    Well.....Thats all I did to it.coolant Temps are now at 196 degrees with A/C on. It was 96 degrees outside yesterday. Before I added the oil the temps were going up and down from 197-219. Apparently, it made a difference. Im certainly not complaining.
  18. Remove Advertisements
