Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Are there any good oil additives to add...
    limoguy is offline Cadillac Owners Fanatic
    Automobile(s): 98 Deville Delegence
    Oct 2007
    Long Island, NY
    198
    Question Are there any good oil additives to add...
    ....to my 98 deville north* with 120,000 miles on it? She runs good, uses about a quart of oil every 2,000 miles. Im just tryying to keep everything running properly. thanks
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Re: Are there any good oil additives to add...
    If it ain't broke, don't fix it. 2,000 mpq is right on target for a healthy N*. You'll notice in your owner's manual that GM recommends no oil additive.
    Oct 2007
    Long Island, NY
    198
    Thumbs up Re: Are there any good oil additives to add...
    thanks for the good news submariner
  5. #4
    Feb 2004
    FL
    2,250
    Yes, GM's engine oil supplement (EOS)
    Please note that EPA nazi's have discontinued the product. It is however still popping up on ebay.
  6. #5
    Feb 2006
    56,868
    eldo1......EPA's nazis didn't pull EOS off the shelves, GM did because people were using it as a constant oil additive and messing up O2 sensors and catalytic convertors. Most GM sites are now selling a (don't quote me...) Redline product as a substitute.
    Early in the summer there was quite a thread about EOS, and one of the posts called attention to the fact that GM had changed the label to specifically NOT recommend that it be used as an everyday supplement. (The handwriting was on the wall...)
    I have 2 cases of the stuff and use it for what it is: an engine assembly lube.
    Why? Because I build flat-tappet Chevy 454 and Olds 455 boat engines.
    Some roller stuff, too.......
    Why hype a product that is now Unobtainium ?
  7. #6
    Oct 2007
    Long Island, NY
    198
    thanks..im going to keep an eye on the level, change the oil when nessesary & thats the end of it!!
  8. #7
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,287
    Wynn's Friction Proofing, Pyroil, Riselone, Casite, Motor Honey, STP, Slick 50, Zmax, TCP, Holt's Piston Seal, Marvel Mystery Oil, CD-2, Bardahl, Lucas, Ecotek 100, Fin Lub, MOV, Bitron, Flashlube, Duralube, Mainline 255, Hyperlube. I'm sure there are many more. Try all these out and come back so I can give you an additional list.
    Don't mess with Binky Bear!
  9. #8
    Oct 2007
    Long Island, NY
    198
    Red face Re: Are there any good oil additives to add...
    wow...are you sure its a good idea to use one of them in the northstar?.
  10. #9
    Feb 2004
    FL
    2,250
    Quote Originally Posted by submariner409 View Post
    The EPA pressured GM to discontinue the product (in the US only).
    My sources tell me it is still available in Canada...
  11. #10
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,287
    Quote Originally Posted by limoguy View Post
    Everyone of these additives has had their 15 minutes of fame that somehow seemed to coincide with a mass media advertising campaign. If anyone of them was significantly better than the others or had any benefit at all it would be the only one on the market. They all base their performance on the same basic components, duck butter, hucksterism, and hype.
  12. #11
    69
    82,284
    Bottom line is change the oil when the OLM tells you to (or sooner) and don't add any snake oil.
  13. #12
    Oct 2007
    Long Island, NY
    198
    sounds good..thanks ranger
  14. #13
    racetek27 is offline Cadillac Owners Member
    Automobile(s): none
    Nov 2010
    57
    19
    zMax successfully helped oil burn and noise problems on the Northstar engine. GM Cadillac Division issued a PI recommending it on cars experiencing these problems.
    Bob Is The Oil guy site has great info on zMax . Look it up.
    Thanks
  15. #14
    Feb 2006
    56,868
    Quote Originally Posted by racetek27 View Post
    zMax successfully helped oil burn and noise problems on the Northstar engine. GM Cadillac Division issued a PI recommending it on cars experiencing these problems. Bob Is The Oil guy site has great info on zMax . Look it up. Thanks
    Curious that zMax has been in and out of court with the Federal Trade Commission several times for making unsubstantiated advertising and product performance claims.
    What is the GM Technical Service Bulletin number for this product ??
    ...........and, while the "bobistheoilguy" sites are interesting to read, remember that they are sponsored by oil additive manufacturers. You have to study it all - not only what you want to believe............
  16. #15
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    40
    718
    ive used Lucas. As expensive as it all is, (i have 3 cars that burn oil) the cheapest additive ive ever used is.........
    More oil.
  • You may not post replies
