squeeky serpatine belt *new belt and tensioner*
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Northstar Engines and System Technical Discussion Discussion, squeeky serpatine belt *new belt and tensioner* in Cadillac Engine Discussion; any ideas whats causing this belt to squeek. mostly after sitting all night and first 10-20 minutes driving. driving me ...
    fpmesiIII's Avatar
    fpmesiIII is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Cadillac Seville STS (167k)
    May 2005
    Western NY
    473
    any ideas whats causing this belt to squeek. mostly after sitting all night and first 10-20 minutes driving. driving me nuts.
    its hard to drive a cadillac and have so many little problems that make it sound like a yugo.
    69
    82,163
    Re: squeeky serpatine belt *new belt and tensioner*
    Glazed belt, an out of alignment pulley or a bad pulley bearing.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    wouldnt a bad pulley bearing make the noise all the time?
    69
    82,163
    Probably, but if it is loose, then the pulley may wobble and the belt will squeak. Take a look at it. If all the pulleys are running true, then I'd suspect the belt. You can test it by spraying some water on the smooth side of the belt. The water will act as a temporary lubricant. If it quiets up, R & R the belt.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    yeah i was wondering if it was the belt. it seems to be name brand. NAPA belt. the mechanic says its not the belt because its new. i put a little water on it earlier today from reading previous posts. after i did it and started it up it still screeched. but i just went out now and started it up and there was no screech. i have noticed it sometimes chirp when taking a hard turn when its acting up.
    should i spray the water when the engine is idling or off?
    update: still squeeks even after water was sprayed on serpatine belt.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    my car is probably the biggest lemon and i treat it like royalty dumping so much money into it. problem is it runs like brand new when its working properly which is intermittent. so its tough for me to give up. plus i dont have the money to purchase a new car. and that old saying "once you go cadillac you dont go back" is so true. tough to buy anything else. cadillac makes exciting cars. i could never see myself driving some jap mobile.
    69
    82,163
    Idling for better distribution.
    Perhaps it is a bearing.
    I hear you. Bought my first one 33 years ago. Haven't and won't drive anything else.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    Thanks for all the information, much help. I will suggest the pulley bearings next time I have it checked out. Probably wont be till Thanksgiving break the way things are going. Because I' am away at school and it is tough to get home.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    well I did few WOTs on the way home last night and today It hasn't squeaked. Its weird the more your rough this car up the better it is.
    69
    82,163
    Remeber what the Guru used to say, "Drive it like you stole it".
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    well the squeak is back. i think whenever it gets below 50 degrees it starts happening. any ideas?
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    now mechanic says the alternator is bad!?!? and causing the squeaking. gonna cost $340 to fix. any suggestions?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,582
    FWIW, I had an '85 Mustang GT which was priced out and ordered by me in 3/85. The serpentine belt (and its replacement) never did stop squeaking when cold. Not in 75k +. Go figure. (and no matter how hard I drove it, it never threw a belt.)
  16. #14
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    another mechanic now said that it is a bad pulley bearing. is this worth the fix, sometimes this noise sounds like a barge train.
  17. #15
    69
    82,163
    A squeaky bearing is a dry bearing. It will only get worse and eventually fail at the most inopportune time. I'd fix it now.
  18. Remove Advertisements
