stuttering at idle
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, stuttering at idle in Cadillac Engine Discussion; Either way, i am having a issue with the car going ahead and surging a bit at idle. The car ...
    Crown Vic Owner is offline Cadillac Owners Connoisseur
    Automobile(s): 98 sls
    Aug 2007
    1,305
    stuttering at idle
    Either way, i am having a issue with the car going ahead and surging a bit at idle. The car starts to stall almoost, revs itself, and is fine. Is it possible that the IAC is starting to take a dump.
    69
    82,180
    Re: stuttering at idle
    Could be the IAC or IAC air passage in the TB. Have you cleaned it? Maybe a vacuum leak or wires starting to get bad.
    jar240 is offline Cadillac Owners Member
    Automobile(s): 2002 DeVille
    Oct 2007
    San Antonio. Tx 78238
    7
    Hey new here, but i just bought a 2002 Deville, not 500 miles after i bought it started having idle problems and P0300 code. (multiple random misifres) Took it back to the dealership and said if they didnt fix it they could have it back, so they fixed it. It turned out to be a leak in the intake manifold. Go figure.....
    Aug 2007
    1,305
    suprising.
    Never really common on these cars.
    IDK, a few WOT runs, its fine. Figures.
    69
    82,180
    Quote Originally Posted by jar240 View Post
    It was more likely the "plenum" or rubber coupler between the TB and the manifold. Seems to be somewhat common on 2000+ engines.
    rockybalboa11 is offline Cadillac Owners Fanatic
    Automobile(s): '94 Seville STS N*
    May 2007
    247
    sounds like ignition coils to me
    does it happen more often when the car is still warming up to normal running temps?
  9. Remove Advertisements
