Aluminum Block porisity
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Aluminum Block porisity in Cadillac Engine Discussion; While getting parts for my ignition system I section cut a block .upper right is the bottom of a head ...
    zbuickman is offline Cadillac Owners Member
    Automobile(s): northstar ignited Big Block
    Aug 2007
    43
    21
    PostAluminum Block porisity
    While getting parts for my ignition system I section cut a block .upper right is the bottom of a head bolt hole and lower left is the main journal. you can see how many holes are in the aluminum . pretty low quality casting. The block halves are still bolted together so you can also see the sealant and oil gallerys.
    In the other picture we see the cast in sleeve and the water jacket. notice the porisity here as well. I can definatly see why a timesert should be used on a H.G. R&R
    just my .02
    99Classillac's Avatar
    99Classillac is offline Cadillac Owners Enthusiast
    Automobile(s): Ex-99 Deville owner, Now-04 DTS and 05 DTS. ZX6R Pilot too.
    Nov 2005
    Upper Marlboro, MD
    34
    841
    Re: Aluminum Block porisity
    That is pretty sorry casting
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,216
    I repaired the transmission case on a Porsche that was way worse than that. What you see there is pretty standard for pressure die castings. If you want to eleiminate porosity you have to go to sand castings.
    Don't mess with Binky Bear!
