GM Oil Consumption TSB, 2007
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, GM Oil Consumption TSB, 2007 in Cadillac Engine Discussion; Late yesterday I ran across this TSB while looking up some info on my car. GM Oil Consumption Guideline TSB ...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,547
    GM Oil Consumption Guideline TSB #01-06-01-011D of April 03, 2007.
    I have been unable to successfully change the file extension from .htm or .txt in order to upload it as an attachment here. Perhaps AJ or one of the GM/Cad techs can help.
    The TSB is 5 pages long, but the phrase which caught my attention basically states that GM gasoline engines in cars and light trucks, from 1998 on, should be expected to have an oil consumption rate of one quart per 2,000 miles or greater. This apparently changes the old school thinking in here. The TSB goes on to discuss driving conditions, aggressive driving, engine wear, etc., etc. It's a long read, but very informative.
    Hopefully, one of our computer literate techs can upload it..........
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    49
    6,919
    Re: GM Oil Consumption TSB, 2007
    I think this part right here sums it up for most of us.
    Aggressive Driving High Speed or High RPM Driving
    Aggressive driving and/or continuous driving at high speeds/high RPMs will increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected.
    A higher rate of oil consumption is normal for vehicles equipped with manual transmissions that are driven aggressively. By "aggressive," we mean operation at high RPM (3,000 RPM to redline), with frequent use of engine braking (using the engine to slow the vehicle). Vehicles that are driven aggressively may consume engine oil at a rate of up to 0.946 L (1 quart) every 805 km (500 mi). This is normal for a vehicle that is driven aggressively. No repair is necessary. This characteristic does, however, require the owner to check the engine oil level at sufficiently frequent intervals, especially when driving aggressively, to assure the oil level remains within the recommended operating range. As the Owner's Manual recommends, you should check the oil level every time you get fuel.
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    Heres the entire TSB - a couple dealer check things at the end.
    Engine - Oil Consumption Guideline Info.
    Bulletin No.: 01-06-01-011D
    Date: April 03, 2007
    INFORMATION
    Subject:
    Information on Engine Oil Consumption Guidelines
    Models:
    1998-2007 GM Passenger Cars and Gasoline Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)
    2003-2007 HUMMER H2
    2006-2007 HUMMER H3
    2005-2007 Saab 9-7X
    Supercede:
    This bulletin is being revised to include information on manual transmission vehicles and additional warranty statements.
    Please discard Corporate Bulletin Number 01-06-01-011C (Section 06 - Engine/Propulsion System).
    All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. As a result, varying rates of oil consumption are accepted as normal in all engines.
    Oil Consumption
    The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
    Certain 2006 and 2007 models have a new GM Extended Warranty. Please refer to the appropriate Owner's Manual for warranty information.
    This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or 80,450 km (50,000 mi) for Cadillac, driven at legal speeds in an unloaded (for trucks) condition.
    This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more.
    Many factors can affect a customer's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption.
    Gasket and External Leaks
    Inspect the oil pan and engine covers for leakage due to over-tightened, damaged, or out of place gaskets. Inspect oil lines and fittings for signs of leakage.
    Improper Reading of the Oil Level Indicator (Dipstick)
    Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked.
    Operating your vehicle with an oil level that is below the minimum level indicated on the engine oil dipstick can result in severe engine damage. Repairs resulting from operating an engine with insufficient oil are not covered under the terms of the New Vehicle Warranty.
    Refer to Owner Manual in SI for checking and adding engine oil.
    Not Waiting Long Enough After Running Engine to Check Oil Level
    Some engines require more time than others for the oil to drain back into the crankcase. To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked.
    This does not apply to 2006 and 2007 Corvette ZO6 equipped with the 7.0L LS7 engine (dry sump). Follow the instructions in the Owner's Manual for checking the oil in this application.
    Improper Oil Fill After an Oil Change
    Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality.
    Towing or Heavy Usage
    Towing a trailer will increase oil consumption and may cause oil consumption to fall below the normal accepted rate referenced in this bulletin for an unloaded vehicle in a personal use application. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption.
    Crankcase Ventilation System
    Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use.
    Oil Dilution (Fuel and Water)
    On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, unburned fuel and condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture and fuel, may give the customer the impression of excessive oil consumption.
    Engine Temperature
    If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order.
    Engine Wear
    Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption.
    Measurement of Oil Consumption
    Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).
    Verify that the engine has no external leaks. Repair as necessary.
    Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
    Park the vehicle on a level surface.
    Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that the oil has had time to drain back into the crankcase.
    Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual.
  5. #4
    Feb 2006
    55,547
    "You da" man!!" Ranger and I are eternally grateful (speaking for myself.....) You have to dig a bit to find out that '98+ N*'s are in there, but it covers a lot of vehicles. I wonder, I just wonder, if some of the change of policy wasn't brought about by the likes of us pinging on dealer/service personnel?? Nice thought, but then.......(In any case, specific reference to this thread-TSB will cover a lot of bases for Administrators and Moderators observing the Oil Wars.)
  6. #5
    68
    81,748
    I seems strange that the General would lower the oil consumption rate from 1qt/1000 to 1qt/2000. That is going to raise their warranty expenses.
  7. #6
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,171
    I suspect they're pretty safe. I haven't owned a car of any brand in the last thirty years that required the addition of any oil at all other than my Mazda RX-7 Turbo with an oil injection pump for the rotor seals. My CTS 3.6L used no oil at all. My STS Northstar V8 uses no oil at all.
    Don't mess with Binky Bear!
  8. Remove Advertisements
